21 - 40 of 40 Posts
Vendor
Discussion Starter · #22 ·
Benefits of Kinetic Recovery
The Master Pull Super Yanker kinetic energy recovery rope is one of the most effective recovery tools you can carry in your vehicle. Compared to static tow straps or chains, the benefits of using a kinetic recovery rope are night and day.
The key feature that makes the Super Yanker kinetic recovery rope so effective is it’s ability to stretch. When put under load, it will stretch up to 30%, which introduces many benefits during vehicle recovery.
First and foremost, this stretch greatly relieves the sudden shock and jerking commonly felt during vehicle recovery, effectively reducing the amount of stress put through a vehicle and its occupants.
Static tow straps and chains are not designed for shock loads, so the pulling vehicle must first gain tension on them before it can begin the vehicle recovery. This doesn’t allow the pulling vehicle to gain any momentum before having to bear the additional forces of the stuck vehicle.
With kinetic recovery ropes, some slack can be left in the line before the pulling vehicle starts the recovery, allowing it to gain much more momentum and therefore gaining a much higher pulling force. Since the kinetic recovery rope excels in absorbing shock, it will simply stretch under tension and then transfer all the energy gained from the pulling vehicle to the stuck vehicle.
The ability to leave slack in the kinetic rope is extremely advantageous when the pulling vehicle is in very loose terrain, such as deep sand, snow or mud because it allows the vehicle to get moving before it actually starts feeling the weight of the stuck vehicle. As mentioned before, a static line must be tensioned before the pulling vehicle can actually start recovery, so when it begins accelerating, it already is feeling the weight of the stuck vehicle. In many cases, the pulling vehicle will not make it anywhere and just bury itself instead of recovering the stuck vehicle.
7/8" Super Yanker Kinetic Recovery Bridle - 28,500 lbs
CALL 706-559-9609 or post up for pricing!
Vendor
Discussion Starter · #30 ·
Performance Recovery Gear
In the off-road world, dealing with a stuck vehicle is just part of the game. Since 1996, Master Pull has been trusted by top competitors and recreational off road enthusiasts around the world for their vehicle recovery gear needs.
We supply only the highest quality recovery gear, from synthetic winch lines and snatch blocks to kinetic recovery ropes. Wherever the trail may take you, Master Pull has the recovery gear to make sure you can tackle any obstacle in your path.
Synthetic Winch Lines
Extreme strength: 30-60% stronger than steel wire rope
Lightweight: 80% lighter than wire rope
Safe: No whiplash or snapback in the event of breakage
Torque free
Easy to handle: No kinks, burs, or splinters
Floats in water
Chose from
Basic The classic winch line. High quality, affordable price.
Superline Higher strength in a smaller package.
Superline XD The ultimate winch line. Best abrasion resistance and strength
Call us at 706-559-9609, Post Up, or PM us for your needs!
Vendor
Discussion Starter · #34 ·
If you are looking for a great winch rope or offroad recovery gear, then look no further than MasterPull.
They have tons of options on length and strengths.
There is something for everyone from MasterPull and CCOR.
Pm, post or give us a call today for your recovery quote today @ 706-559-9609
Vendor
Discussion Starter · #38 ·
Torque free
Floats in water
Chose from
21 - 40 of 40 Posts
