I have a 2012 and received a Rugged Ridge Dual Battery mount. It was a gift and the web site it was purchased from and the Box listed 07-14 JKs. Yeah, nope, it doesn't For I tried massaging and squeezing. It's not going to happen.
The old one has been cut up For the install so I can't reinstall it.
Has any one used the MORE 12+ Dual Battery mount? Suggesting on the best place to buy one.
The MORE is an easy straight forward install. The fancy part is going to be the wiring for the dual battery. I have the Painless wiring kit.
The only things with the tray install that I differed from the instructions are;
-complete removal of the fuse block. I didn't do that just disconnect the ground and 12v supply wires. You can get the tray out around that.
-i cut the tray before completely removing it. Not necessary but cutting off the part your not keeping makes it easier.
- the EVAP valve they say just to move it and reuse the lines. You can take off part of them and not use them. But I'm going to end up replacing some with rubber hose.
