1 - 20 of 23 Posts
So, im 20 years old & just now getting into the jeep community. Like the rest, i hate the low power 3.8l v6 in my 2wd automatic 2010 jeep jku sport. My jeep is i guess u can say bone stock. No power windows, no cruise control, nor remote start, none of the cherry things that comes in the newer jeeps. I've come here not for price ranges, but to find out what parts do i need to do an l83 5.3/6l80e swap. I dont have to go through inspection where i live so not worried about the smog. Also, where can i find each item to buy separately over time? & what can i do if i decided to do an 4wd swap next? How do i go about it?
I don't get it ... why would anybody buy a 2wd jeep?
Contact @JohnPShoe at Overland Performance in Louisiana , 225-304-6288 .
He will get you taken care of .
I am in the process of gathering everything to do an L86 swap into a 2012 JKU.
I have a Motech kit on order, they are the only ones selling a kit, the other shops only sell it if they are also doing the install.
Since you have a 2wd Jeep, it leads me to believe you are trying to not spend money on this. If that’s the case, DO NOT go with a gen V engine. It’s a lot more costly than a gen 3 or 4.
If you want to do the swap like a “hot rod” which would make the drivetrain stand alone, then be prepared to figure out how to make all the other systems in the Jeep work. Everything goes through the Jeep computer.
Making it 4wd at the same time would be fairly easy, but likely not too cheap.
If you’re just looking for a little more power and 4wd, step into a 2012 or newer, it’ll save you a lot of money. If you’re looking for 4wd and big power, be prepared to break open the piggy bank!
Is Motech producing DIY kits now for the gen V? Last I heard they only had a few batta kits out there and where still doing only in-house builds.
Yes, but with the note that it is not yet fully supported. As I understand it, there are difficulties with some of the gen v engines- car pulley systems, 2017 and up engines have locked computers and I don’t think they have tested all the various platforms - lt4, etc.
If you have an L83 or L86 pre 2017 it seems to be fairly straight forward. I’ll let you know when I get mine done. I plan to wrap it up in March.
I’m putting a L83 in my 2005 LJ Rubicon. The PCM crapped and it’s NS1 now, no longer a supported part. I’ll be using the Holley mid mount to address pulleys and lack of power steering pump. Pulling the I6 this weekend.
Ya keep us updated. I have looked into it some but hadn’t heard that yet.
The truth is not clear about the locked computers , as I understand it there are just a few types that will be effected .
GM's Australian Holden being one , there are a few others but , Very Few , will be affected .
If you are talking about OE certification , well that's another matter .
All computers would be "locked" , there is a system within that would show that someone was in the computer and it would probably get the build rejected for certification and a registration or a license plate in the state that would allow the swap based on the OE requirements .
About the only way you would be able to have a "custom tune " is to have two computers and hope you don't get caught in a spot inspection running the "hot" computer .
Clarity on these issues will be known WHEN and IF a swap company finally receives OE certification .
There is a lot of money and time to be spent by the company to achieve this , good luck and hard work are the reward to the company that gets there , they will have a real winner especially in Cali , CARB certification is just the last obstacle to get beyond .
I wish I knew the truth , but I don't , only those that are working on it know , but they aren't talking .
Hi there,
With an older Jeep, and a 4 wd swap ahead, I would also recommend a gen 4 and 6l80 swap. I did the gen v L83 engine with 6l80 trans and had to work through some challenges making it work in my 2011 JKU. Mine is the change over model with the 3.8 but new 2011-2018 interior.
Given the extra time and work it will take to make your Jeep a 4 wd I would go for the more straight forward gen 4. Maybe you can score a 6.0?
I don't think Cali is ever going to accept a Chevy engine in a Jeep product.
Watcha' doin' , takin' all the hopes and dreams from the masses in the land of Moonbeam .
From the rumor mill , work "is" being done in an effort to make just that happen , no way to get concrete evidence of that , but that's exactly the rumor from the mill .>:)
This is reason 4829 to never live in Cali. Here in Onterrible (Ontario) Canada, we are scrapping our drive clean emissions testing program in April. You currently need to pass to renew your licence plate sticker which expires on your birthday. However since my birthday was a couple weeks ago, I need to get my truck to pass, to get my sticker to be legal for the winter. The Jeep can wait till spring to get a new sticker so that way I don’t have to test it. :thefinger:
Our test is a computer that they plug into your OBD2 port and it checks your VIN and to make sure all of your emissions equipment is functioning properly. I’m not sure how an engine swap would effect this. It may just check the Jeep VIN and the Emissions equipment, or it may say that the test is for the doner vehicle. I’m guessing that most LS swaps run all the emissions equipment through the GM ECU which has a VIN for a GM vehicle.
Since the whole program is going to be shit canned in less than 4 months I’m not going to take the time to find out. :thefinger:
They do. It is a little more complicated but not impossible. MoTech has several LS swapped JKs in California, Nevada, Colorado and several other states that are Nazi's when it comes to emissions.
Really? To me it seems that when they get asked point blank.........they say no. Or is it more of a case of some guys just getting lucky?
I'm just glad my LS swapped Jeep will be legal to drive in all the states you mentioned. Cause it has Louisiana plates.:thefinger:
I'm a little surprised some people do not know about Robby at MoTech and how may LS swapped Jeeps are on the road with full emissions.
1 - 20 of 23 Posts
