Do it , I'll give you a few hundred for your rippThis thread makes me want to sell my RIPP and get a Motech. Holy shit guy, great answers. Thanks for your candor and not sounding like a salesman.
Pretty easy not to sound like a salesman when your product sells itself.This thread makes me want to sell my RIPP and get a Motech. Holy shit guy, great answers. Thanks for your candor and not sounding like a salesman.
Remember, there are a couple members of our club that recently did V8 swaps in their garages and now can't smog. Research the shit out of this because the criteria for the referee to approve it is ridiculous (must have donor trans, donor emissions, donor exhaust, etc.). Shit, the referee will take one look at your fuel cell and laugh. I would talk to Jeep Speed shop about options - or just get the CARB approved RIPP supercharger.In the end... if she has issues smogging, I'll eventually do something like ALASHA has outlined.
California is even worse than Colorado with the visual bullshit. Basically, you have to find a smog shop that will cheat. The smog process in California involves cameras and computer links with every smog check being monitored by the state. California has a separate law enforcement agency that conducts "sting operations" on test centers. Because of this, the guys that cheat on tests usually don't stay in business long. There were two shops in my county that used to "cheat" the visual for the off-road and hotrod guys (for a little extra $$), but they have both been closed by the state.I know in Colorado, my 6.7 Cummins passed the "smog" sniffer test, even with the DPF and EGR systems deleted. So it burns clean enough... but it failed "visual inspection" because I tampered with it. Therefore receiving a FAIL.
Thanks, let me claify my point. Several years ago when we offered out Gen 1 kit it was priced at $3,195, it was pretty bare bones and included mostly hardware. Our Gen II kit added more electronics for better functionality, and it works great, a Gen II 6.2 is what I drive everyday. We also added a lot of items to make the kit more complete, like a coolant bottle, air intake tube with MAF, GM ECM preprogrammed, Jeep PCM programming, shift lever, etc. In addition we modify your shifter, Jeep engine harness, a/c lines, etc so the kit is as plug and play as possible. With the Gen I kit you had to make those modifications yourself.Motech, if at the time that I purchased my supercharger had the price been comparable to between the s/c and the 5.3. Hands down would I have done the 5.3, in fact I still do, but at the 12-20000 range couldn't even consider it. So if that 5-8000 range comes up just might be a s/c up for sale.
Thats a new motor and labor done by someone else. I think Brodon is referring to a DIY swap using a used 5.3Brodon I don't think you are going to see under $8K, when 5.3 turn key starting at 18,900 plus when you add cruise control and few other stuff its just over $20,000. I agree spending 20K is just not even a remote possibility for me too.
Did you drive a jeep or a car?I drove the 5.7 swap from V8HJ here in Phoenix last week and it really pulls like crazy. This car had a cam and a fairly aggressive exhaust so it was a bit more extreme that my setup will be. Of course, the power difference was night and day compared to my sorry 3.8. Fit and finish was flawless and absolutely zero issues (no cels, no overheating, everything works, etc.). They do not "mask" the trouble codes, their computer setup simply doesn't have any.
Sorry I did not snap any photos. My JK has an appt about 3 weeks out.
Come on, get with the times. Now that rock racing is so big, "car" is the new cool kid term for any off road vehicle.Did you drive a jeep or a car?
I don't understand the comment in red. You are happy with the motech and that it burned out your jeep?All I can say is if you do not want to follow the advice people have given on this forum and YOU DO NOT have a good to great understanding of the jeep AKA Chrysler Can Bus and GM Can bus, depending on which way you go Hemi or LS, EXPECT HEADACHES!!! Coming from experience here with a MO TECH kit and a burned out jeep unless this is a off road only build type you will build something that most likely no one but a select few will ever want! The greatest comment you will ever get with a build is a stranger taking a look at your build and scratching his head and the first comment he makes is I quote "This looks like factory!" and when you can actually sell something like this which will eventually happen down the road if you like to build stuff and not loose you arse!! I like to modify stuff and this was the most pleasurable build for me. Never have messed with EFI or Canbus architiectures which just like and other PLC device needs to be correct or you will suffer the consequences, bad gas mileage, drive ability issue, convince options (electric windows, door locks, interior lights, radio, dash, horn, air bags, lights, wipers, battery charging, starting, security, remote start, remote locks, fan control, anything tied to the anti lock brake system, any Can Bus controlled via Chevy and most importantly the jeep side via the TIPM or fuse box because of Chrysler's Canbus design. If you do not allow someone with the know how to help in these categories unless you are into major pain and learning curves that have taken some of these folks years to learn and considerable amount of money to design this could be your biggest can of worms you have ever seen. If you do it and succeed you will have done something few have been able to do without some kind of help so Cudos to you. Just saying from experience!!!
P.S. If your are savy you can do this build for under 8 grand. Start adding bells and whistles of course the amount will go up. Happy! Happy! Happy!
No I think this is the guy who started with a burned Jeep so the OEM wiring was toast.I don't understand the comment in red. You are happy with the motech and that it burned out your jeep?
