1 - 16 of 16 Posts
I know I took a pic of a thread detailing the differences between the jeep 3.6, 3.8 and the dyno number were way off than the advertised hp of the two. I would have sworn motech had done them but after an hour of looking for the thread and finding nothing. Anybody remember this? I want to say the 3.8 was around 135 and the 3.6 was not much better.
I don't remember the thread but I did see a dyno sheet of the 3.6 being at 185 hp ish as advertised.
Random Dude
You talking about crank horsepower or wheel horsepower vs. "advertised HP"? :dunno:
Here's a necro-crosspost of @ALASHA stating ~50% loss at the wheels about a decade ago (see bold red portion):
356 rwhp out of a 345 hp 5.7? :shaking:
I can tell you that the stock Rubicon drivetrain on stock Rubi tires losses right about 50% as measured at the wheels, so the 3.8L v6 makes 205 at the crank, I had 106 measured at the wheels.
THEORETICALLY, apply the same loss to a 345 5.7 and you SHOULD see ~172 at the wheels.
Here's a graph from a thread in 2012 (linked):
I thought there was a thread recently with big-engine dyno numbers, but can't find it :(
Maybe it was a meltdown thread and the OP was a HGPD-ing, no-class-havin' mu'fugger :laughing:
EDIT: Apparently Ripp claims/sees (or did 5 years ago) 33% drivetrain loss, based on this post:
Cool man!
445hp = estimated crank HP?
295 at the wheels (assuming RIPPs oft quoted 33% drivetrain loss)?
OK, I'm done googling shit :laughing: - here's my secret: MAGIC FINDY-LINK
Real world averages are 30-35% drivetrain loss on a JKU ......
Have seen as much as 45% on some personally . bot those were new tons with big heavy tires and wheels .
After some berakin' i would expect to see better numbers , but not much .
The averages are less with light shit , more with heavy shit .
I know the original @ALASHA dyno was done here in Colorado Springs at approx. 5800ft. I know our air sucks here. I don't know if that is corrected for DA.
Random Dude
Good call, dude! :beer:
If true, that reconciles the "30-35%" folks with ALASHA's ~50% results.
Also, per my (NIST-traceable, meticulously calibrated) butt dyno: going from ~sea-level to 6-7,000 ft., the 6 squirrels under the hood seem ~20-30% less enthusiastic :laughing:
For comparison sake here is my hellcat wrangler on pump gas with a cam, upper and lower pullies and 1000 cc injectors. Dyno was a dynojet with 35” tires due to roller width.
Went back to my original thread to double check. Those numbers were with a full atmospheric correction. Pulled on a Dyno Dynamics load bearing dyno which tend to read lower than others.
Also phuck photobucket.
Um, you're going to have to share a bit more about the build..........like everything.:thefinger:
It’s a 2013 10th anniversary with full custom suspension, oris, dynatrac 40 spline 60/80 combo with big bell rcvs. Custom cage, prp seats, built southern hotrod nag1 tranny, atlas tcase. Running right at 1000 Hp at the crank.
Very clean. How are it's street manners?
Surprisingly not bad. We used a mmx smooth boost controller so we can basically turn the power down if needed. When all the way down it feels about like a stock Jeep. The suspension is extremely stable and almost no body roll but with the way I have the ori struts adjusted for Offroad I do get a ton of front end lift due to the rear suspension geometry. If you have Instagram I post there for the most part.
https://www.instagram.com/p/B8PtvRDnJYE/?igshid=11tl3qz2akdga
1 - 16 of 16 Posts
