Well as promised here is the newest donor for my next project. This is an apparent home built utility trailer with plywood floor and 15" tires on unknown capacity axle. The rough measurement of the deck area is 4' x 8'.
The end result will be a 4'x7' flat utility with new 12" side rails, expanded metal floor, LED lights, 3500# axle with 5 on 4.5 hub, but most important will be a completely removable tub that can be used for expedition runs, then stowed, allowing the trailer to be used as a normal utility trailer.
This trailer will hopefully be ready for the Savannah Poker Run, if not well, guess I'll be bringing the Mule again.
