1 - 11 of 11 Posts
I have a 2007 JK on a 2" Black Diamond BB kit. My question is- Can you install a set of 2 door or 4 door Rubicon springs and still keep the BB lift installed? If you do what changes to do you have to make in addition to installing the springs?
You can, but I don't see why you would waste your time on it.
Not enough to be worh the trouble. At least not for me. How much lift are you going after?
If you put rubi springs from a 4 dr on, assuming yours is a 2 dr, you'll get a little extra lift out of it, not sure it would give you 2" but maybe an extra 1" to 1 1/2 maybe.
Like to be around 3.5 to 4" total... For now
Then buy some 3" springs. Poly Performance has them $300.00 for a set. Otherwise, I'd just leave well enough alone. The stock spring lift dealio is too hit or miss, even with the right springs as jkristie posted.
I put a set of Rubi Unlimited springs in mine (ending in 17 18) with a 2" BB and ended up with 4 1/2" total lift. I started out with a 2dr X, plaine Jane
Discussion Starter #11
What other changes were needed?
1 - 11 of 11 Posts
