I purchased a rough country 2.5 inch budget boost. I've been reading lots of info in the 5 months I've had my 07 Sahara jku. Most lifts budget or otherwise recommend wheel spacers with factory wheels. I have 33x12 or 12.50 tires and have put washers in the steering stops to stop rubbing on sway bars at full lock. Is the lift gonna cause something else to run or is the recommendation of wheel spacers just for stability after raising the center of gravity? I'm hoping to install this lift Wednesday so any advice will be much appreciated
Sent from my PG86100 using Tapatalk
