I was going to install my BB lift this weekend but just remembered that I didn’t order my sway bar disconnects.:shaking: Can I raise the 2.5” and rotate the sway bar down and use the factory links until I get them?
Use the rear swaybar links in the front and run no rear sway bar. At least that is what I did. You can order longer links for the rear if you want and some JKS quicker disconnects for the front. Don't run your stock links though cause your sway bar may flip over causing damage.
Discussion Starter · #3 ·
I just installed the warrior 2.5” BB and the JKS quick disconnects this weekend and had no problems. Of course my wife’s first words were why didn’t you go higher? And the other part of the plan is working well. She keeps telling me that it would look better with bigger tires. She broke out some of my part mags and has informed me that pro comp rims with mud terrains would look good on it. Now I just have to save the cash.
