When my jeep was delievered, the passenger front tire was low.....I asked of they had done any dealer prep and they hadn't. I could understand why, because I had ordered it though jeepwarehouse.com and had it delivered in Lodi. They pulled it back, filled up the tire, checked the fluids and I was on my way
I am not one who generally checks my tire pressure every day and about 1.5 months later, I notice that my spare and pass front tires are low again. THe tire was pretty much worn down on the corners, so I filled it up (after checking for nails)and figured that I would check it more. Another month the spare has 6lbs and the pass front is down to about 15lbs. Worn more so I rotate it to the back and fill it up once again. I happened to be washing it and I noticed that the spare was bubbling around the valve stem. I check the worn tire and it is doing the same.
Has this happened to anyone else?
