IMO, it would be better to get rid of the body lift and do a 2-3" suspension lift. I ran 35's with a Teraflex 2.5" lift a few years ago. Just got another JK, so I'm starting over.
Yes running a suspension lift would be preferred but to answer your question, yes you can fit 35's with the lift you have. Spacers depend on the backspacing of the wheel you are running. If you are running stock wheels then yes you will need spacers. If you are running aftermarket wheel with 4.5in of backspacing or less then you will most likely not need spacers.
No way does he have a 3" body lift, he just doesn't know the correct terminology to use. No way, not in a hundred years.
Sent from my XT1650 using Tapatalk
fake account.
