Tired of having your JK suck ass in the power department.....? The JK Power Pack we have put together has proved to be an awesome addition to anyone looking for more performance for their Jeep JK. Below is a list of bolt on components included in the kit.
Price = $950.00 Shipped anywhere in the lower 48......
CLICK THE LINK TO ORDER ONLINE or call 805-783-2060 to order over the phone.
AFE Stage 2 Air Intake System:
-Increases horsepower up to 5.7 HP
-Improves torque up to 7.75 lbs/ft
-Maximizes airflow for better acceleration and responsiveness
-Improved performance results in greater fuel efficiency
-Installs in less than 60 minutes using factory mounting points
-No cutting or drilling to engine compartment is required
-Replaces OE air filter with high flow, high performance 360 degree radial flow air filter
-Washable/reusable air filter with the deepest pleats in the industry is the largest possible in the space allowed
-Replaces factory air box with a heat-blocking shield that seals to the hood
-Replaces factory intake tube with a custom-designed intake tube that accelerates airflow to the turbo or throttle
-Limited lifetime warranty
Edelbrock Cat-Back Exhaust System
-2.5" in, 3" out
-50 state legal
-Unrestricted Flow and Superior Performance with CNC Mandrel-Bent Tubing
-Patented Sound Deflection Technology Cancels Out Unwanted Resonant Noise
-Delivers the True Sound of Performance
-Designed and Manufactured by Edelbrock in the USA for Easy Bolt-on Installation
-Ti-Tech Coating on the Muffler Provides Resistance Against Heat and Corrosion
-16-Gauge Aluminized or 17-Gauge Stainless Steel Construction
-Most Systems Include Polished 304 Stainless Steel Tips
-Will Not Void Manufacturers' New Vehicle Warranty
AFE SilverBullet Throttle Body Spacer
-Gains up to 10 horsepower & 14 lbs/ft Torque
-Combination serrated/helix design creates turbulence so that air/fuel charge is thoroughly mixed for complete burn
-Precision machined from solid T-6061 billet aluminum to exacting specification for optimal performance
-The additional space increases the volume between throttle and cylinder improving volumetric efficiency
-Available only for applications that show dyno-proven results
-The serrated entry reduces annoying whistling sound especially at idle and cruising speeds
-Fifty state legal (CARB EO# D-516-2)
Hypertech Max Energy Programmer
-Increase of up to 11 Horsepower & 24 Foot/lbs. of Torque
-Improved Fuel Economy
-Internet Updateable (USB cable included)
-50-State Emissions Legal
-Easy Plug-And-Play Installation
-Speedometer and odometer correction for tires from 22.5" - 44" in diameter
-Read and clear diagnostic trouble codes and turn off check engine lights
-Lower the cooling fan on/off temperatures to match thermostat rating
-Return the vehicle back to stock setting or change options at any time
-Two different performance tunes for regular or premium fuel (manufacturer claims +8 hp / +16 ft-lb increase on regular fuel and +11 hp / +24 ft-lb increase on premium fuel)
-Adjustable top speed limiter
-Adjustable Engine RPM "rev" limiter
-2.5" in, 3" out
-50 state legal
