No one is making anything close to this system....it kicks ass... check it out!
The heart of this Off Road Package is the JK LO-PRO System. It is the sleekest and cleanest rack in our product line because it fully integrates with the factory hard top and roll cage. ……..the main features of this system are….
Modular Design: For ultimate versatility, this system can be configured in many different ways depending on your needs.
An EZ Access system: is provided by Rocker Walk Side Steps, Hinge Steps, the Kat Walk and grab holds.
It’s Expedition Quality: All components are over engineered for long-term, heavy duty use. Ensuring durability and a rattle and noise free installation…. which are hallmarks our design.
A Low Profile Design: Reduced wind drag improves economy and lower center of gravity providing improved road and trail handling. The low pro base system adds a mere 2.5” of height for ample clearance to park in your garage or carport.
The JK LO-PRO System is designed specifically for the JK 4DR Hardtop, which is a hybrid rack solution delivering the lowest rack height in the industry… AND… the heaviest loading capacity:
The Full JK LO-PRO system is made of three main components:
The CONGO PRO FRONT HOOP: It’s 2” in diameter, made of high grade tubular steel and anchors at the windshield-frame mounts….which are factory engineered to support extreme loads.
It functions as a load and light bar, and features weld-on grab holds which are useful for climbing in, out, or on the vehicle!
The JK LO-PRO FRONT TO BACK RAILS: These made of high grade steel, they are 1-5/8” in diameter and span the length of the JK Rooftop….. And they are compatible with factory freedom panels.
And the loading platform, which is the JK MOD-RAK LO-PRO KIT…..is right sized at 46” x 52” inches.
It’s boasts light-weight aluminum deck panels, which are traction surfaced and walk-on strong.
The platform features built in T-Slot aluminum rail sections for additional load handling accessories, gear holds and containment options.
The milled and anodized Aluminum Fence Kit provides excellent load securing and additional accessory attachment points.
The 1-1/8” diameter bars of the Aluminum Fence kit are industry standard sized for aftermarket bike racks, ski racks and other outdoor gear handling attachments.
The Fence Kit also provides a full containment area for additional bulk loading capabilities of the JK LO-PRO Kit.
The system has a marine powder coat finish on the steel and hard anodizing on the aluminum to protect against rust and scratching…. and it all comes with a Nationwide lifetime frame warranty
The JK LO-PRO System; It’s the New Baseline for overland expedition adventure!
It is PN# 55040....Available at Quadratec, 4WD Hardware or 4Wheel Parts or our website: kargomastersafari.com
