1 - 2 of 2 Posts
JK front and rear axle pair
JK front Dana 30, 4.56 gearing, stock axle shafts, upper and lower C gussets, Teraflex ball joints, Poison Spyder differential cover, complete hub to hub including ABS sensors and stock tie rod. Brakes are not included. Axle is straight with no problems.
JK rear Dana 44, 4.56 gearing, Eaton Truetrac , Ten Factory Chromoly upgraded axle shafts and Teraflex differential cover. Brakes and brake backing plates are not included. Axle is straight with no problems.
Axles are from my 2015 Jeep Wrangler JK and were recently removed at 56,XXX miles. C gussets, ball joints and regearing were professionally installed around 30,000 miles ago.
These axles are a direct swap for any 2007-2018 Jeep Wrangler JK/JKU.
Asking $2000 for the pair.
Axles are located in South Florida.
Let me know if you have any questions
1 - 2 of 2 Posts
