1 - 10 of 10 Posts
I need to install floor mats and a cargo liner in my 2018 2-door Wrangler JK Sahara. I hate to spend $350 for the Weathertech mats and liner, but does it fit and protect the best? Are there any other ones out on the market that fit just as well? WT makes a liner with an integral roll-out bumper protector, which is an excellent idea; I have only seen them from WT; anyone found them elsewhere?*
I also would like to put mudflaps on the rig. Do the Mopar OEM ones fit and work the best?
I was never a big WT fan. Little too commercial for me. But I ended up getting a set upfront in my JK. Things are basically indestructible. Honestly, I can't even remember when I bought them, it's been so long.
With that said, I wish someone would make a (JK) floor mat that comes up over the lip and covers the plastic surrounding the carpeted area. I had this for my TJ years ago and loved it. Really protected the cheap plastic getting in and out of the Jeep.
WT has one issue. Because it does not have the upper piece (goes straight up and stops) it tends to bend away from the side plastic. If it went straight up, then horizontal and covered some of the plastic around the rim, I would give it 5 stars easily.
I can only speak from experience. My XJ runs
WeatherTec mats and cargo mat. They do well at retaining slush/mud/debris/water but tend to fold around edges oddly sometimes...
My JKU's very first "mod" was a full set of the HuskyLiners and man are they a quality product that fits like factory. It's the older ,diamond-plate pattern set. Kinda costly but over time they prove they are worth it .
Thanks for the reply. My wife has WT mats in her car and I noticed the limitation regarding the door side lip (or, the lack thereof). For the $10 worth of material that goes into a set, you would think that a few cents more for a door side lip would be a really good value and make sense, especially for how much that you pay for a set. But, it seems like every set from every mfg is made that way, so, maybe it's a manufacturing limitation. But, I find that hard to believe since they are probably just vacuum-formed in a press.
yup. it's an injection-molded world we live in ....
i still have a set of these in my 07 that have done a great job of keeping crap contained. The drivers mat has a hole worn from my heal but all in all, a great product.
I have a set of the in my wife’s 4Runner and we love them. I want a set for my jk but also want bedrug. I had bed rug in my tj and there is no way to secure the mats to it so it would kinda be a waste
I ended up buying the WT mats and the Mopar mudflaps. I got a decent deal on the mudflaps from Extreme Terrain, and they were super easy to install; I didn't have to remove the front or rear wheels. I'm happy with the WT mats (especially the cargo liner w/ the roll out bumper protector) but I was a little concerned about the 4 cut outs for the rear seat attachment points. I was worried that mud or water might get down in those areas; for what you pay for the mats, you would think that WT would supply some type of removable plug. I looked on line to see if I could find a square tube cap that I could modify to fit, but I wasn't able to find anything large enough or to match the dimensions of the cut outs. I had a piece of 1/2" semi-rigid insulation board laying around, so I used my redneck engineering skills and ended up making my own removable plugs. I wrapped them w/ black Gorilla tape to make them semi-waterproof and to match the color of the cargo liner. Since the seat attachment points are not flush w/ the floor (they are recessed), I hot-glued some extra pieces of the insulation to the under side of my caps to help hold them in place and fill the recess. The pics show the results.
1 - 10 of 10 Posts
