Hi
My 2014 JKUR rear e locker won't disengage and i stared digging to find out a parts catalogue. i wasn't ready to buy a whole diff lock case which cost around $1000 give or take.
in my case i believe i have a weak wave spring which cannot push back the dog gear to its normal position when unlocking or it could be too worn slid ring inside the Magnetic actuator which could prevent the actuators ring to retract to normal position because its can bind. I haven't yet to take my locker a part to check out what wrong with it. And YES I HAVE REPLACED MY PLUNGER AND ITS INSTALLED CORRECTLY.
just want to share this with you guys that Spicer catalogue and part# for rear dana 44 which can help the community to find cheaper fix for our JKs.
@eng.zeo, did you find a source for the wave spring? I'm having the same problem. The last several times I've used my locker, I have had to use a screw driver to pry the plate over. This last time the plate moved over, but the dogs are still engaged.
