JK Bi-Xenon Handmade MultiColored Remote Controlled Headlights (DIY)
Hello Everyone. I am just got done retrofitting my headlights and I would like to share with you.
The shroud I got came with the very poor quality lights and I upgraded inner and outer rings with the COB led lights + Outer Ring did not come with the Lamb Shade I installed the lamb shade for better quality look!
http://s33.postimg.org/5kl0x5oa7/20160427_170238.jpg
http://s33.postimg.org/7gcem22i7/20160427_173911.jpg
http://s33.postimg.org/eyvjuotv3/20160427_220923.jpg
http://s33.postimg.org/mhep3bl7z/20160429_140021.jpg
http://s33.postimg.org/urvwxere7/20160430_181353.jpg
http://s33.postimg.org/q3p3tpgz3/20160501_215114.jpg
http://s33.postimg.org/iej2qi1pr/20160501_215149.jpg
http://s33.postimg.org/ke49vnlf3/20160501_230512.jpg
http://s33.postimg.org/u1cdj43sf/20160502_113655.jpg
http://s33.postimg.org/vhnw196pb/20160502_185434.jpg
http://s33.postimg.org/8vn629icv/20160506_163058.jpg
http://s33.postimg.org/souoh86cv/20160506_163116.jpg
http://s33.postimg.org/t1hh9nz8v/20160506_163202.jpg
http://s33.postimg.org/kogdsqpf3/20160506_230433.jpg
http://s33.postimg.org/6qy7nfrcf/20160507_164319.jpg
http://s33.postimg.org/4g4qx05yn/IMG_9750.jpg
YouTube Videos :
As far as the remote controller goes, the adapter had the IR receiver but it was too short and it is impossible to remote control the lights because the adapter installed on the engine bay area! So what I did was I extended the IR receiver from adapter to inside of the vehicle. It works like a charm.
Enjoy!
Ring Sizes
160mm Multi colored COB ring
100mm Outer Led ring with lamb shade (White)
80mm Inner Led ring with lamb shade (White)
To make the shroud perfect fit, you need to use dremel. Other than that I used Butyl Tape to put the headlight cover back on, And I used 2 INCH CAP END COVER to cover the hole behind the Headlight. I sealed all the open spaces with PL S30 Black Roof sealer and let it sit 12 hours. ANd the result was impressive! It is not an easy DIY since I am pretty handy but it is worth to spend any money and time for this beautiful set-up! If you can not do it I can build for you!
Bi Xenon Kit came with the Plug and Play cable set. But it was for h13 sockets. I purchased h13 to h4 cable converter. Everything works with the factory light switch. And EVERYBODY STARING IN AWE AT my Jeep :)
#Cheers
Are you sure it was in awe, or did you you just hear part of the word?
Not at all my thing, I do appreciate the effort you went through to achieve your desired results.
:beer:
Maybe you should add SOME at the end then :D Thank you tho :)
