1 - 10 of 10 Posts
Hi all, tried searching quite a bit but have not found any leads. I have a 2012 JK with the 3.6 and AT with, presumably, a bad head based on code recurrence and frequency. I'm over the 150k mile extended warranty Jeep offered. Rather than wrestling on a new head and having to be dead nuts on the dual cams, timing, etc. I have been exploring swapping the entire 3.6. I see them pop up quite often from Hemi and LS swaps, and at the local salvage yard. Question is, are the newer 2015, 2016, 2017 3.6 Pentastar motors a direct swap with a 2012? I could get a '12 or '13 from the salvage yard with under 80k miles, but for only a few hundred more (based on prices I've seen) I could get a 2016-ish with under 25k. Anyone have any info on this? When I look on car-part.com '12 and '13 seem to stay grouped together as do the '14 - up and RIPP has a similar separation but I haven't been able to connect the dots...
I think 12-13 were the bad head issues where casting sand plugged up and ruined the entire cooling system. Long block part number is 68264741AA for a 15. The 12 is 68274396AA. I would say call the dealership and ask. The transmission is the same. What I dont know is if the tipm, or pcm is the same... Checkout moparpartsoverstock.com
you are talking an easy head swap and even most dealers are going to be in the $600 range and if you have mechanical skills should be under $225 for parts and a few hours labor. basically and plug and play.
The dealership wanted me to play paycheck roulette to figure out if its a bad lifter or the actual head is bad - I actually don't have the tick, which leads me to believe its the head or valve train - I'm getting all the right misfire codes and crank/cam misalignment to suggest the same. I had it in when it was under 150k but wasn't up for dropping that kind of coin, as I was expecting it would be warranty. So rather than giving them the money, I can just about pick up a new engine. I have limited tools and experience in terms of setting up dual cams and timing, but am confident based on previous projects I can take a motor out and put another one in. Plus, then everything is newer, not just one top half of the motor.
Just for fun, and anyone who is follows along, I did find one additional detail, that the block castings are the same, as expected but there is a difference in the temp sensor threading - not that it should matter for a full swap. 2012 Temp Sensor Hole 3/8" x 18 NPT and 2016 Temp Sensor Hole M12 x 1.5. So far this is the only discernible difference I have discovered.
They seem to start around $1500 complete - meaning pumps, belt, cats and motors mounts included. Miles are the biggest factor, as one would expect
I have been looking into a new 3.8, and they are running about $3000 to 3200.00, for the remanufactured..., Any where from $400.00 to 600.00 for core charge...just a little input..
Swap completed!
Just in case anyone ever digs this up...I found a '16 JK 3.6 motor with 15K for $1500 from a guy who swapped in an LS, so complete and running well with no CEL or issues. I can confirm all the harnesses, plugs, wiring, etc. all the same it seems for the 3.6 - the only notable difference is the coolant. I found this out ahead of time, and flushed the heater core and radiator (though I also replaced the radiator at the same time of completing this) to ensure no HOAT (orange) coolant was left in the system. Upon completion, refilled with the proper OAT (purpleish) for the '16 year motor. I also noticed a ton of oil had collected in the intake plenum of the motor I removed (153K) because of how the Pentastar PCV recirculates the crankcase air through the PCV to the intake, and decided to also install a Moroso air/oil separator. Although it only had 15K I also took this opportunity to install new plugs and the new-ish MSD Blaster ignition coils and all associated plenum and TB gaskets. Runs FANTASTIC. I didn't realize how tired the old engine was until we dropped in a new heart, much smoother, and already a 1-2MPG increase just around town. Enjoy!
1 - 10 of 10 Posts
