1 - 12 of 12 Posts
Hi everyone, I have a 2012 JK sport, and i'm looking to upgrade my stock sound system with the addition of a subwoofer and the replacement of the stock speakers. I am trying to do this while maintaining the factory head unit. Any suggestions? And or pros/cons of keeping the factory head unit? I'm also trying to keep the project to a minimal cost, but still see good results... the standard sound system in my jeep is quite terrible.
I replaced all my speaker with the Boston Acoustic speakers that come in the some of the Chrysler cars they are better but not great. There is also the Kicker speaker upgrade but the Boston Acoustic and Kicker are plug and play. The factory head unit is terrible so your system is limited from the beginning. What sub are you looking at?
I need all the hockey gear to fit in the back still haha, so maybe like a kicker 10" or a bazooka sub. I've heard some good things about the hideaways but not quite sure yet. I wanted to keep some of the stock functionality, such as steering wheel controls from the head unit, are there any option to bypass it? But to still have control of the system?
There isn't any real con to running your OE deck, if you're upgrading your speakers and adding a sub (As I assume you don't have the factory sub?) you will be either adding an amp or a powered enclosure. I am not a fan of Kicker but they have become a "budget" brand. You could swap out your OE speakers with Kickers add a Kicker 5-channel and a 10", be under $1k and it would be night and day. Depends on what you want out of it, what types of music you listen to, what you are sourcing from (radio, cd's, ipod, etc.) & how much space you want to lose. Hope this helps.
What brand would you recommend/currently use? No I don't have the factory sub/kicker upgrade. Mostly sourced from my iPhone, I listen to decent amounts of country with an equal amount of bassy type stuff, sorta the whole spectrum. Any other tips from that information?
Thank you! :)
I have all Alpine Type R's, In the past I was big into JL, Eclipse, & a few others. Alot of guys here have Polk & Kicker. To correct myself nothing wrong with your OE deck IF you will be powering your replacements with an amp. Alpine Type S's would be a step up from Kickers or Polks IMO, but a full Type S (components up front, 2 ways up top, amp and 10") setup prob would be more in the $1100-$1200 range. You tryin to keep the head unit to look stock? I feel ya on the need for hockey gear I have 2 boys that play almost year round between the ice and inline.
Cructhfield.com has good aftermarket head unit usually with free install kits. They will also point you in the right direction on how to keep your steering wheel functions and sat. radio. I will be doing this soon but I got to have factory functions as well. BTW we don't have water let a lone ice down here in Texas, so instead of hockey gear I got the back filled with 2 Earthquake Sound 15s, overkill, I think not.:nono-1:
Thank you! :)
Quality starts from the source (head unit). The factory radio outputs voltage to the amplifier, allowing it to power speakers/subs. In order for you to have decent quality sound, you have 2 easy options. 1. Replace factory radio with aftermarket head unit, all parts including dash kit, antenna adapter, data harness, and steering wheel control interface module. This way will be your most expensive route, but arguably the best way to do it. 2. Keep your factory radio and add a piece made by a company called Audio Control. They make a piece called an LC7i and it works great with a factory head unit. It will allow you to take the very low, insufficient voltage (around .5 volts) from your factory radio, and boost the voltage all the way up to 8 volts (depending on max input rating on your amp.) What this will do, is allow you to keep the gains turned down on your amplifier while maintaining great sound quality and volume. It also erases the factory EQ settings that are originally intended for the factory speakers, giving you a flat signal in to your amplifiers, then make your LP/HP curve adjustments on the amp/s. There is a lot that you can do to make it great without breaking the bank.
Hope this helps
1 - 12 of 12 Posts
