Jeep Wrangler LED Turn Signals
Click to order or for more information:
Front Turn Signal LEDs for 1997-2006 Jeep Wrangler
Front Turn Signal LEDs for 2007-2017 Jeep Wrangler
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
HP24 Switchback:
The HP24 bulbs use 16 amber, and 8 white LEDs. They are very high-power chips. More importantly, the amber is a custom-made LED chip. Instead of a standard amber, which emits a low-energy amber light, the amber LEDs on this bulb are downconverted from blue, just like a standard white LED. It is extremely bright amber. Equipped with full aluminum body for durability and advanced digital latching circuit for color control. 6000k, Cool White to match your HIDs or other LED applications.
Included in your order is TWO BULBS.
Hyperblink Fix: The turn signals on most vehicles will begin to blink fast (hyperblink) when LED bulbs are installed. This is because LEDs use less power than the original bulbs, so your vehicle thinks that the bulb is out. There are two ways to fix this:
Resistor Kit: This is a universal way to fix the issue, and will work for any vehicle. By adding a resistor to the bulb's circuit, you can mimic the power consumption of the original bulb, and return the vehicle to normal turn signal speed. The installation takes 10-15 minutes, and involves making two simple connections. Everything you need is included in the kit. If you have both front and rear LED turn signals, you usually only need one set of resistors, on the front or rear, to create enough resistance for the turn signal circuit.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty. For more information, please view the FAQ guide.
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
(Single Color Amber Options)
