not to much of a write up as just some things to look out for.
the directions are good just need 11mm not 10mm as stated in directions
if you have a dealer installed 7pin tow harness you need to get some slack on it to get enought room for the canister to fit, also if you have a River Riader breather kit you need to get the evap around that also
I want to update this with a few pictures. I have a 2" Rusty's lift and that gives me 6" between the diff and the canister, 5" between the axle and stock bumpstops. Assuming the foam doesn't compress more than an inch I should be good.
Also, the "required items" page of the installation instructions doesn't mention that you need hose clamps, but the instructions do call for them.
Here is the unit ready to be installed:
Here is the unit mounted:
Reminder- you have to drill 4 holes in the tub:
Vendor
Thanks for posting up the details. The hose clamps are not required and I need to fix the instructions. They don't hurt anything by being on there though.
