So i got a 4" superlift put on my jk about three months ago... after i got the lift done it seems that the back end of the jeep is a couple inches lower than the front.. what could possible cause it to sag or is it just some optical illusion im having? or is it because my tires look to small for the size lift i have?
Could be a number of things. Some lifts come higher up front to correct for stock rake. Only way to rule out the optical illusion thing is to break out the tape measure. Measure from the street to the bottom of the fender, front and rear, and compare.
Mine sat perfectly even until i put a rear tire carrier on, now its about 3/4 inch lower in the rear....
Check from the top of the tire to the fender front and rear.
i dont know if id use the word sag....but im higher in the front by a little..but i think thats alot better than the slammed front stock look
