1 - 2 of 2 Posts
So I just finished installing a RE 3.5 spring lift on my jk. Came with bilstein shocks, installed extended sway bar links in the rear and disconnects in the front. RE adjustable track bar and rear track bar relocation bracket. I am now getting terrible death wobble as in every time I hit a numb going over 30mph. Will be trying to diagnose the problem tomorrow and update, I'm guessing track bar is not
torqued to specs or possible ball joint worn out (105xxxmiles) also my tires are worn heavily
Sent from my SM-G935V using Tapatalk
At a MINIMUM you need something for your front lower control arms. Adjustable arms or dropbrackets from the likes of AEV.
Also invest in a draglink flip ASAP. Synergy makes a great kit.
I would not run 3.5" springs without the above.
1 - 2 of 2 Posts
