1 - 20 of 23 Posts
Hey everyone. I installed my Warrior Products corners with LED's about 4 months ago. They're great products and worked great for about 3 months. Then just awhile ago, I started to get a fast blink issue only on my passenger side. My driver side is not affected and works like a charm.
I say it's a fast blink issue, but not what you think. Here's what happens:
The issue is with my high beam tail lamp on the pass side. The low beam is for the driving light, the high beam is for the brake/signal. Whenever I start my Jeep up, the issue isn't there. High beam light comes on when I brake and signal. Now it's when it gets weird. When I'm going 50 or slower and around town, nothing goes wrong. The minute I hit a highway and maintain 60 or more mph for any period of time, the light goes off. No signal, no brake light, and the fast blink comes on.
I shut the Jeep off at a stop light, turn it back on, the issue goes away.
WTF.
First I thought it was the LED. Told Warrior Products, they told me to swap LH and RH lights and see if it was the lights. It wasn't. The issue was still on the pass side.
They sent me a new resistor. Changed that out. Re-spliced and re-soldered everything. Checked all my connections. Taped the heck out of every exposed wire. Didn't work either. Hit a highway, lose my high beam light.
Not exactly sure what's going on. Something tells me it's my Jeep's electronics. I also have a hunch my Jeep just doesn't like LED's. So my next move is to switch back to my halogens and see if the issue goes away. If it does, my Jeep Hates LEDs. If it's still around....... then maybe I chance going to a dealership to get my electronics checked out and pay an arm and a leg to get it fixed.
I'm somewhat at wits end. Anyone have this weird issue happen to them? Or theories?
Well I think it's a WP product issue. I have the steel rears and after I unlock the doors, then open any unlocked door my passenger side brake-light/LED flashes once. It's the only one that does this. I don't have any other LED's on my Jeep right now.
From the time they were installed (around April 5 or so) until present it does this and the dealer installed mine since they were doing everything else.
Tech said it was a relay or something causing my issue. Load resistor could be bad???? I don't know maybe they're not getting the juice they need over 60...don't know why that would be.
I would check to see how they are wired again, proper ground (if needed). I didn't see what came in the box so no instructions.
Installation guide: CLICK
I have the same flashing light happen when I open doors as well. Always on the pass side only. Yours fast blinks too?
I installed led front amber run/blink bulbs and it makes my blinkers fast blink. I am getting ready to install rear led tail lights/blink, do I need anything special or do I just tap into the exist wiring?
Depends what lights you're getting I would imagine. There appears to be two options when installing the WP steels. THe install instructions are under post #2.
OP - the wife said that they do not blink fast, just appears like it since there is not a dim-to-full-on-bright on the LED's. She also hasn't noticed anything odd, or wrong, with the WP steels. I haven't had anyone rear-end me yet. :)
Maybe check the wiring again, don't know really.
You would probably need to install a resistor in parallel to the LED to fool the system into thinking the loads are similar to your stock setup. That gets rid of the fast blink.
is there a specific one? I had to do this on my HID headlight setup also. I tapped it in through the selinoid.
I have PSC corners and Truck-lite LEDs and have the same two issues on the passenger side. I have a resistor on both sides. Posted up something about it a while back. Seems several folks have this issue ...doesn't really bother me.
Discussion Starter #10
It doesn't bother me either except when I want to turn right lol. Mine's a DD so I might have to ditch my LED's and go back to standard bulbs.
Discussion Starter #11
Bumping for more input...
my lights came from 4wheeldrive hardware they had genrite stickers in the box but I just think they are trucker lights wich is fine, I bought 2 1/4 inch white LED for the rev light.
Something is up with the resistor kit..to make the leds flash right there are in line resistors to help the voltage output. My or fab led lights did this. Ran ok for a few weeks and now the right side has an issue..got a new resistor kit from them and now all's kosher
Discussion Starter #15
Turns out the issue is with my jeep. I reinstalled my stock lamp, ran it down the freeway and the exact same issue occurred on the stock setup.
Being that this is such a specific failure mode (on highways and at speed) and that it affects a stock setup as well, I'm thinking it's an issue with my TIPM. Will continue digging.
Wanted to say thanks to warrior products and their amazing customer service. They helped me thru the entire process and were very prompt and friendly. I am very happy and impressed by them!
Your factory tail light WILL CONTINUE to blink fast for a bit after switching back. It takes a bit to re-set.
go to auto zone/pep boys/whoever, go in the lighting section, look for the LED replacement light and right there should be a resistor kit for like $12.
wire it in.
here is mine wired in and completely heat shrunk (they are white ceramic)
Discussion Starter #17
I have the resistor. I bought it with my WP corners. I actually didn't have any issues running my LEDs for the first three months. Then my electronics went bad and all my issues began.
thats...odd :laughing: mine blinked fast as soon as I connected them.
so its still doing it with ALL factory lights? Are all lights working? did you replace the electronic blinker relay?
Every vendor is selling the same damn resistor in regards to rear tail lamps led replacements.
And frankly it's a miracle if anyone's jk doesn't fast blink or throw a code with led tails.
The problem is a 3157 bulb has a specific resistance that the computer looks for.
The only way to stop the fast blink and or codes is to match the 3157 bulb within +\- 10%
I actually had a resistor custom made so that the resistor plus the led tail adds up to the
proper load and resistance for a 3157 bulb.
Works like a charm, it looks like I might be signing up for vendor status.
Sorry for the partial hijack
Cool! Where'd ja get it made?
1 - 20 of 23 Posts
