Just wanted to know if jeep has the button that is labeled "fog lights" as for example sway bar or axle lock, since i want to put it there and maybe one of you veterans might know.
I'd like to give credit to MichaelW for using his picture above.
Broker by the Minute
No problem on the pic with the credit, thanks!
From what I know the switches are a one piece bank and you can't cut it up or the switch bank doesn't work. So you can't put another switch in there. I haven't verified this so you may want to wait for someone that has done a different switch to chime in.
Interesting note, while running through my manuals today I discovered that one option on the JK is to have electrically adjustable head lamps. And the cover plate that indicates AIR BAG stuff is the switch that controls the 3 positions of the electrically aimed head lamps. So does that mean that the switch bank can be modified or is there a whole other switch bank part for the electrically controlled head lamp aiming.
Things that make you go hmmmm. ;)
14ers
"Electrically aimed headlamps" ?? I never saw this option. What else am I missing? Maybe I can make my neighbor with the Lexus jealous in a whole new way... :laughing:
As for the foglamps, why not just use the factory switch on the end of the stick? Or are you looking to add more?
The adjustable lamps aren't available in the states, you have to jump the pond for that option:bawling:
