1 - 1 of 1 Posts
Hi guys, happy Friday, would appreciate any nudges in the right direction on an issue I'm troubleshooting. 08 JK 55k miles, 2.5 frankenstein/RK lift with rancho 9ks, steel braided brake lines.
I've been hearing a hissing/grinding noise which comes and goes. I have not been able to identify the exact source but it's been getting worse. Speed is not a factor, it comes and goes. If I hit the brakes it kind of stops but will start up again once I'm off the brakes. If I'm going slow enough and it's happening then it's less of a hissing and more of a rubbing. It sounds like it's going in rhythm with tire rotation.
I pulled the pass side front and couldn't see any issues, even the pads look great which I'm guessing is because it's a manual and I tend to just downshift.
On the driver side front I found what is pictures. The brake line looks like it's fraying a little where I drew the arrow, and obviously there is some fluid. Two things come to mind:
1. Wtf happened to the line, how could anything possibly rub it in that spot?
2. Is this somehow causing the noise or red herring?
I haven't lost enough fluid for it to be noticeable in the reservoir if that matters.
pic: Imgur: The most awesome images on the Internet
1 - 1 of 1 Posts
