Vendor
Safe storage space is always a plus if you drive a Jeep with an open or a soft top.
It's a well known fact that a vehicle with convertible roof attracts car thieves much better than a vehicle with a regular hardtop because of the obvious reasons.
These storage boxes by Best top are designed to protect your valuables and give you a piece of mind.
There are two cool boxes that fit under the seats or in the center console of a Jeep Wrangler.
# 1 Bestop® - Underseat Lock Box
- 205 cubic inches of storage space in sliding drawer
- TJ Wrangler dimensions: 12" x 8" x 3"
- JK Wrangler dimensions: 16" x 5 ¾" x 2 7/8"
- Comes with pick resistant lock and 2 keys
- Manufactured from heavy-duty 16-gauge carbon steel
- Textured black powdercoated finish resists corrosion
- Attaches beneath driver's seat using OEM seat riser bolts, no drilling required
- Passenger side mounted box available for JK Wrangler
- Heavy-duty braided steel locking cable included with TJ Wrangler box, so box can be attached almost anywhere in almost any vehicle
- Includes hardware and instruction
See the way it looks in real life on this YouTube video:
Installation instructions
# 2 Bestop® 42643-01 - Black Lock Box for Center Console
- Designed to fit in the center console of Jeep Wrangler (2 door and 4 door models) from 2011-current.
- Comes with 2 keys
- Depth 8 1/2". Lid 6 x 5 1/2"
Which storage box would you pick for your Wrangler and why?
If you need a quote just PM me or leave your comments below! Don't forget to include your zip and email :)
Vendor
The boxes are good for 4 door models 2007 and UP and 2 door models 2008-2010,
Unfortunately the passenger side box will not fit on the 2 door model 2007 and 2011&UP.
the underseat box WILL NOT work on a 2-Door with the Tip and Slide seat . You would need to replace the seat bracket with a 4-door bracket or use one from an older 2-door to make it work.
The only one option for 2011 and UP 2 door models that will fit with no modifications is the Lock Box for Center Console.
