I have a 2012 unlimited. I bought the magnum RT steps with the light kit. I am trying to figure out which wire to tie into so when the interior lights or key fob are activated, the lights on the steps will come on. I wired it right to the fuse box. but the lights stayed on all the time. I need to find where and which wire to connect to so the lights will work properly. Thanks in advance for all of you help!
Your going to have to find a wiring diagram of the door wiring harness or either test the wires at the door harness.
Sent from my SM-N910V using Tapatalk
you can tag it in the passenger side kick panel.
you are looking for the dome light wire.
It is a yellow wire with a white stripe.
You're Welcome.
