Installing rear axle shafts
66903 Views 69 Replies 34 Participants Last post by  MUD707
Replacing the Jeep Wrangler JK rear axle shafts with the Superior Evolution Rear Axle Kit is a relatively simple task. The kit comes complete with both axle shafts, bearings seals, collars, and wheel studs. There are different kits for the Rubicon Dana 44 (32 spline) and non Rubicon Dana 44 (30 spline).
If you are not going to re-use the factory retaining plates and ABS tone rings, then you will to purchase these seperately. It makes sense to do this, as you will then be able to leave the factory shafts intact and ready to be used as spares. You will also need to replace the four torque bolts on each retaining plate, as they should not be re-used.
  • Retaining Plate - Mopar 68008523AA (2 required)
  • Retaining Plate Nut - Mopar 68003275AA (8 required)
  • ABS Tone Ring - Currie CE-11320 (2 required)
Superior Axle shaft compared to factory shaft. They look very similar, the difference is in what they are made of and the cold-formed rolled spline process that produces axle splines that are up to 35% stronger than traditional cut splines. The way the bearings are fitted also differs slightly.
First thing you will need to do is press on the ABS tone rings. These need to clear the shaft collar by approx 1/8"-1/4", do not go further than 3/8" or they will no longer line up with the ABS sensors. The opening of the tone ring should be facing outwards towards the hub end of the shaft.
Apply grease to the axle seal and place the retainer plate axle seal on to the shaft, followed by the bearing and collar. The inner bearing surface is chamfered on one side, which indicates the way it goes on the shaft, chamfered side towards outboard end of shaft. Then press the bearing and collar on to the shaft, until the bearing seats on the lip on the shaft. Every time you have built up pressure with the press, it is a good idea to release the pressure and rotate the shaft in the press 90°, this insures that bearing and collar are being pressed on evenly.
Installing the shafts is simple, exlcuding the lug nuts there are just seven bolts/nuts that need to be undone for each shaft. First, remove the caliper and rotor, then undo the four retaining plate nuts.
Remove the bolt on the ABS sensor and pull the sensor back so it is out of the way, there is no need to remove it.
The bearings are lubricated by the differntial fluid, so it is a good idea to tilt the axle up slightly so as not to spill diff fluid when you remove the shaft.
The shaft should just pull out, very slight force with a pry bar will help it un-seat if it is stuck.
Looking inside the housing you can see the diff fluid (showing the reflection of the bearing).
Bolt in the Superior lug nuts, some blue Loctite will ensure they do not move. Grease the bearing with suitable wheel bearing grease, in this case Mobil 1 Synthetic Grease, wipe any excess grease off the bearing mounting surface.
21 - 40 of 70 Posts
As far as the bearings go...I am having issues figuring out which bearing to use (buying new)
Timken part # SET10AZ
SKF part # BR10
Both listed as "Wheel bearing - Rear"
OR something like the Omix-Ada part # 1653605 listed as "axle shaft bearing - rear"
Or ar they all the same damn thing?
I did this today. I couldn't get my axles out even by prying lightly against the drum brake. I found that if you put the disc back on backwards and thread the nuts on a little you can use the disc as a slide hammer. Worked perfectly. And, if you are tying to figure out which axle is longer or shorter, make sure you have the lug nuts threaded on. I was trying to put the long axle in the sort side:D
Great write up as always, pulled my shafts to replace a few broken studs :shaking: long story. I used the fliped rotor trick, my shafts wouldnt budge.
Hey PhilD..I just replaced my left rear axle inside an hour.. Really easy thanks for the info.:beer:
Glad it was useful :)
Not too bad.
I just did this today & thought I'd add a few tips for those about to try it. My seal was leaking for a while & made a holy mess out of everything on the driver's side. I used that as an opportunity to replace my axle shafts while I was in there. I used 2 full cans of Brakleen to clean it all up (both sides) plus the wheel & tire.
1. The Brake Caliper bolts & axle retaining nuts are both 18mm. Ratcheting wrench is handy here as access is tight.
2. The ABS sensor bolt is 8mm. I used a 1/4" drive socket & ratchet and a~6" extension to clear the swaybar bracketry on the driver's side.
3. The tip Charles gave on using the caliper as a slide hammer was a good one. :)
4. Don't forget the "Brakleen" for cleaning the greasy fingerprints off your brakes before reassembly. Especially after step 3 above!
5. The Superior Wheel Studs use a 3/4" socket to screw them in. I also used anti-sieze instead of loctite as I think they'll be plenty tight & I want to pull them back apart when I get my Spyntec fronts (to swap bolt pattern). They are 1/2-20 x 2" long.
6. Don't forget the Loctite on the Caliper bolts & ABS sensor bolt.
7. The dimension of the tone ring press on isn't that critical - the sensor has a wide active area. The dimensions shown in PhilD's write up are plenty close enough.
8. I had some difficulty in removing one of the bearing races. Some patience & kept working with it. I was about to break out the slide hammer & bearing puller, but was able to slowly work my way around with a small lever helping it out. Be careful you don't damage the axle tube in this area so the new bearing goes in OK.
9. Because I had a leaky seal, I bought new seals, bearings, and retainers. Now that I'm done with my swap I'll rebuild my stock axles for a good set of trail spares. That and I forgot the kit came with those already! :shaking:
EDIT:
10. Here's 1 additional tip I forgot to mention that I learned from a well-respected shop & pro JK Mechanic: before installing the new axles, coat the outer sealing surface of the new axle seals (the part that contacts the axle tube) with a light coating of RTV. I'm not the originator of this tip, just the messenger, but it comes from someone who does dozens & dozens of gear changes on JK's. I can't vouch for how good it works or not.
That's it. Don't be intimidated. PhilD's instructions are very good.
Good additional info :) I never remember to make note of socket/wrench sizes.
Can anyone recommend a good place to get the tone rings, plates and nuts?
Looks like I'm going to have as much in the hardware as I do in the axle shafts. :(
PhilD can get the tone rings in your hands right away.
Great write up, I'll bump for anyone interested.
Also, I think the brake caliper torque spec is 55 ft/lbs not the 75 noted above.
Its odd to me that the axle shafts are different lengths. I have some stock spares that I got from someone on here. They look exactly the same length and I cant get different measurements from them. How can I go about figuring out which is the long and which is the short AND which side accepts which? I thought the diff in the rear was perfectly centered. :cwm13:
The right side is slightly longer.
You shod be able to line them up and see the difference.
Rubi 44 - one side longer
Other JK 44's - equal length
Awesome! So since I have a non-rubi they ARE interchangeable? Therefore I only have to carry 1 spare.
Thought you were talking about Rubi shafts, glad someone was paying attention...I was not.
Well since you said that I should be able to line them up and tell the difference I knew that was not the case with my shafts so I figured Rubi's must be different. ..... Run on... Oh well :thefinger:
Bumping this one up again for anyone else in my shoes.
Swapping my bent rear shafts with some used OEM replacements until the tons are ready. The info here is awesome and should make the swap fairly simple. At under 11,000 miles I'm hoping the shafts won't give me too much trouble popping out.
My drill press and hydraulic press should make light work of the bearing removal and install. It's been all too long since I've used them- I need to start building things again!
SKF part # BR10
I didn't see a reply to this... are you guys using whatever bearings/seals the parts stores have listed for our Jeeps? I'd rather not have to order them online.
21 - 40 of 70 Posts
