There’s many ways to do this. This was my way. Figured I would share since I have seen many people asking about a BFH with a hitch.
Yes, I know this won’t tow like an F-250 but it does just fine with my little 4X6 utility trailer with BBQ supplies and coolers of beer.
This was completed in two separate phases if you will.
The first phase was just installing the receiver and drilling the holes for the safety chains. A big thanks to my buddy Junnie for welding it up for me.
The second phase I did by myself as a welding project after I bought myself a Millermatic 211.
Phase 1
First, mark the center of the bumper and grind down to bare metal.
Then cut a hole that the receiver tube will drop down in.
Then drop the receiver tube down in the hole. You’ll need to measure the distance between the bumper and the storage tub in the body and cut the receiver to fit. Or you could cut the storage tub if you want.
Fits nice
Weld it up and grind it down
Prime
Paint
Mount
Drill holes to hook safety chains
Phase 1 complete
Everything worked perfectly but I wondered if it needed some reinforcements and I also wanted a welding project since I bought myself a Millermatic 211 and I was sick of welding scrap metal together.
Discussion Starter #2
So, on to phase 2 – reinforcing the bumper
I looked at this for weeks trying to see the best way to do it. Here’s what I came up with. I’m sure there are many better ways but this way is mine.
First, remove the two rear body mount bolts and measure center to center between the body mount holes. Cut a piece of .120 wall 2” square tubing to span between the body mounts and mark the center to center distance. On one side drill a hole big enough for the threaded portion of the bolt to fit through. On the other side, drill a hole that the socket that fits the body mount bolts will fit through. I simply made a piece of 2” square tubing that would bolt to the rear body mounts.
You can see the piece of square tubing in this pic – the rusted piece of tubing behind the bumper
Now to tie that piece of tubing into the bumper
I cut two piece of 3/16” steel plate to fit on the bottom of the square tubing and lay inside the bottom edge of the bumper. Tacked them in place, then removed the whole assembly and welded all around every joining surface and reinstalled to check for fit. Fits perfect. Now the bumper is tied to the tubing that is bolted to the body mounts.
Now to make this whole thing stronger
I cut 4 pieces of .120 wall square tubing that fit tightly against the piece of tubing that bolts to the body mounts, the rear edge of the bumper, and the pieces of 3/16” steel plate from the last step. Put those in place and weld all mating surfaces of all pieces of metal plate and tubing.
Prime and paint
Reinstall
Reinstall and drink beer.
Hopefully someone will find this useful. I love my BFH bumper but find it necessary to pull a small utility trailer sometimes. This allows me to do so while feeling confident that everything is secure.
How do you pin your hitch in the reciever? Not a lot of room under there.
Not a lot of room but there's enough to reach in and get the pin in. It's tight but it works.
I like this a lot! I may have to do this to mine whenever it needs new powder coat.
