I took a little time today and installed the Tera-Flex Hinged Carrier and Tire Mount on the JKU and wanted to share some photos.
I opted to go with both pieces because I am running 35" Toyo MTs on 17" wheels and they weigh in at roughly 100 pounds each. I also wanted the ability to upgrade when I am ready to bump back up to 37s.
The carrier arrived in two separate boxes and the packaging was fantastic. Almost everything you will need for installation is included. They even send an Allen wrench style Torx 50 for the re-installation of the hinge bolts.
Tera-Flex mentions in their installation videos that you should use a block of wood to support the tail-gate while installing. (You remove the factory hinges and replace them.) They accidentally include the perfect support in the packaging for the hinged carrier. There is a thick white foam block that I cut in half and used to support the door. Sweet!
Most of your factory bolts are retained with this setup and the only difficult or frustrating part would be pressing in the wheel studs if you don't have an impact wrench. Otherwise, it is a very, very simple unbolt and re-install type modification.
If you're looking for a clean and simple solution for a tire carrier, this is it. I'm very impressed!
I didn't take many photos of the install because I was hurrying, but here are some photos of it hanging on the Jeep. Notice how perfectly it holds the lines of the Jeep. Very impressive.
