Here is some helpful hints if you missed it in the video:
AN fittings are a 37* flare, NOT a 45* flare like your brake lines, FYI.
AN fittings and JIC fittings are the same and can save you cash, problem is JIC fittings will sometimes not have the options a AN will and most JIC are steel. But for your info a AN6 is the same as a 3/8 JIC.
If you want a hydro assist setup to "fit well" in a JK you will need a 45* angle fitting at the rear box porting and a 90* at the front box porting. The 45* is to clear the AC pulley and the 90* is to keep the hose bend at a better angle.
By "fitting" I mean FITTING, not adapter.
This:
NOT THIS !!!!!:
Something made from a tube or a full flow design. Those short cast ones work "OK" and will be fine for a while but they induce cavitation and heat. The full flow/smooth bend fitting will work a LOT better.
The good thing is this is still a common hydraulic shop items. Just tell them you need a JIC 3/8 hose XXX long with a 45* JIC 3/8 fitting on one end and a 90* JIC 3/8 on the other, have them show you the fittings and get the lines made. If you have a tractor/boat/hydro shop close you can get this done for cheap.
Run a friggen cooler, heat kills pumps. A small cooler is better than none and a big one is better than a small one. Some guys run the "heat sink" style coolers and some run the more traditional style. I am running a plate style that is pretty dam big. Figure what works for your space available.
With me I am not screwing around and you will see
Run a bigger reservoir if you can, more fluid runs cooler and is easier to cool.
I will post up my entire setup hopefully this weekend if the fan comes in and the new parts. Right now it is "fine" but I want it done and finished to my specs
