1 - 13 of 13 Posts
Ok, so I've been reading threads here and other forums feverishly trying to make sure I don't do anything or buy anything that will require supporting mods and risk breaking my jeep.
I've gained a halfway decent idea but there is just soooo much information that applies to different people differently.
I have a 2015 bright white JKU that currently has a 2" Fox/Mopar lift, 35x12.50x17 tires with spacers, rubi rock rails, the factory spare mount with extensions for matching spare, rugged ridge QD trail doors, be stop bikini top, bestop trunk cover, DIY paracord grab handles, and DIY sun shade.
Because it's a brand new jeep, and i had to "buy it for my wife" it won't see any real hard duty until warranties are out and I "buy my wife a Cadillac CTS-V" but that's years away. But it will be used for beach riding and trail riding. Basically stuff a bone stock rubicon could probably do (with my winch i should be as capable.) And I learned my lesson with mud from my diesel truck days (mud is too damn expensive.)
Purchased/traded for are:
Custom front bumper w/ winch plate and stinger.
Tuff Stuff Xtreme 12500 synthetic winch
Custom Molle panel tube doors
Smittybilt fender flares
52" curved Cree light bar and custom A-post brackets.
Next items on the agenda are:
4.56 gears
Lunchbox or LSD front
LSD rear
Axle truss and sleeves
1.25" body lift
Rear bumper/tire carrier
Skid plates
Custom semi-matching off-road trailer
Roof rack
So with light trail duty in mind, is there anything wrong with what I have going here?
I feel like LSD's would better fit my needs, especially with a winch.. BUT, aussie lockers being as affordable as they are im torn. There is a good chance that my wife will have to drive it on ice at some point and I don't want anything that will pose a greater danger.
I've driven my old 600rwhp mustang in the same weather she would be driving in so I suppose she could just keep it in 2wd but i worry about how an autolocker would handle on ice.
My lift is currently warrantied so im hoping a 1.25" with my 2" will be fine. Maybe with a pinch weld trim?
Is there anything im missing?
JKO Dickhead
Drive it like it sits if you don't plan on any serious wheeling - you will be amazed at how capable it is as its sits, bravo for making a winch a priority !
Quick disonnects for the front swaybar if you dont already have them. Disconnecting is just as, if not more important than traction devices IMO.
Well.. When i say serious wheeling I guess I mean like, anything that could risk a rollover, damage to painted panels (ie, needing to ride the rock rails up a ravine), etc. I'll do as much as I can that doesn't risk serious damage to the tub.
I knew that if I wanted to wheel at all i needed to have self recovery taken care of so the winch was definitely a priority.
As far as disco's, i had planned on purchasing replacement Clevis pins for the teraflex kit and making my own, but honestly, I don't know enough about jeeping yet to know when and where I'd disconnect.
I also, already, rub at full lock on relatively level ground. Im sure the pinch seam trim, high line fenders, and body lift will help but could i really utilize the disconnected travel if im having rubbing issues now?
Thank you both for your replies.
Ok so... Upon further research, are the rear pinch seams the only thing anyone cuts? I assumed there were just a lot of write ups on the rear and not so much on the front. Plus I used to dabble in lowered cars when rolling or flaring the fenders was a must.
You have a 15, pinch seam is already trimmed from the factory.
High line fenders: take your pick. Metal Cloak and Poison Spyder are probably the two most popular.
Body lift: no, no, no, no, no, no, never, never, no, not on a JK, no. Is that clear?
Eventually i want to do full skids and gain as much ground clearance as possible. By that time my warranty might be up and I could get a better suspension lift but until then... I've seen as many people for BL's as I have against them, why do you say not on a JK?
Why so adamant about not using a body lift on a JK?
Why should 1"-1.25" body lifts be avoided?
What kind of negative effects do you get from a 1"- 1.25" body lift?
Will he have to alter, modify, or add to his existing suspension lift to run the body lift?
Are they difficult to install?
Do they have a negative effect on steering and suspension geometry?
Do they have a negative effect on drive shaft angle?
Do they decrease available suspension travel to increase tire clearance?
Are they expensive?
Do they require additional parts/components to make the Jeep drive and function properly?
Do they raise the COG higher than equivalent suspension only lift?
A jeep is trail ready off the show room floor, sans tires on some models.
I don't see anything on your list being of a benefit or helping you offroad.
Gears would be good if you are unhappy with highway performance.
Get out and enjoy the jeep, you will find what you need in order to make your jeep more capable for what you are doing with it. The way you are set up now you can run the rubicon trail.
If you are not out bashing on rocks I would avoid skids as you loose ground clearance and gain a lot of weight.
I wouldn't waste your money on anything besides an engine skid, and maybe better sliders - if they are the rubi rails...some will debate that but I don't like body mounted sliders.
No reason to update the crap out of it before you understand the limits, or lack of, the current build.
I would avoid a body lift because there is almost no point - waste of time, money, and the only point is to allow for bigger tires....you can just trim the fenders. I have a body lift that was on it when I bought it - pointless and I want to take it off.
Discussion Starter #11
To each their own. I would like to be able to enjoy my jeep and then, years from now, return it to stock and make her shine again. Good point on the skids though.
I will be having tubes welded to my rubi rails eventually, and have the rear ends cut down a bit since they protrude so far into the wheel well.
Like I said before, I don't want to have to baby it around the trails but I also don't want a ragged out POS in a years time.
I may hold off on the BL until after I see how she does with the fenders and bumper I've got. But, why don't you take your body lift off?
You should disconnect any time you are on a trail where the suspension will articulate.
You are not going to rag out your jeep running mild trails and the beach, big tires are going to do more wear and tear then the trail. If you go into the woods you are going to get lots of custom pin striping on the paint so be aware of that.
Depending on where your tires are rubbing now what you are looking at may or may not stop the rubbing. Properly set up bump stops are likely the solution.
1 - 13 of 13 Posts
