Well seeing as I have no need for the "other" JK forum it is time to move some tech :devil:
and delete it from there :laughing:
Oh and you can also use the same tool to cut new tread patterns but that will be a different thread
This is your typical "Ideal" 250-300 watt tire groover that can be picked up from a bunch of places but the cheapest is usually places that sell "stock car" or "circle track" stuff. I get mine from speedway motors.
Get the size head and blades you think you need, they come in a wide assortment of widths. This is a 1/2" head and blade.
to "sipe" you go and install the blade UPSIDEDOWN with the 2 blades down.
Figure the depth you want and set it at that.
New tires you can set at full depth.
use a sharpie and figure the sipe pattern you want.
WARNING !!! try NOT to sipe the outer blocks on mud terrains, they have a tendency to "chunk" if you do. If you do sipe them leave a good 1/2" to 1" on the outside of the block SOLID.
Pick a nice warm day, the warmer the tires the better. Plug the groover in and let it heat up for a good 10min before starting.
Yes it takes some effort and yes you will screw up a few blades before you get good at it
You will find the pressure and movement that works best.
and TAAADAAAAA
Siped tires. (you can't really see the "actual" sipeing just where the heated head made it glossy)
Better wet and ice traction, they will run cooler and wear better on road usually as well.
and no, it is not illegal
and TAAADAAAAA
