1 - 20 of 46 Posts
How to run 37s with flat flares, a 1" body lift, and 2.5"-3" suspension lift
I've received a few questions about how to do this.
This information has been repeated several times in other threads via copy and paste.
I thought it would be easier for people to find if it was a stand alone thread.
Wheels with more backspacing require slightly more bumpstopping.
The pics below show 17" wheels with 4.5" backspacing and 15" wheels with 4" backspacing. The 4.5" backspaced wheels required more steering stop washers and slightly more front extended bumpstopping.
With flat flares and a 1" body lift, to run 37s you want 0"-1" front and 2.5" rear extended bumpstops.
If you want to do 37s with flat flares and no body lift, you want 1.5"-2" front and 3.5" rear extended bumpstops.
As a preface, lift height alone does not give you the ability to run larger tires.
What matters is flare/body clearance and the length of your bumpstops.
So, here is an explanation:
In the pictures below, I have my winter wheels on...with a OME LT kit (3") from Northridge4x4.
(I haven't reinstalled my wide Xenons for winter yet.)
Okay, the details on how to do it:
37s, OME HD springs (3"), 1" body lift, and:
Cut 2" off stock Rubi rocker guards
Drill holes to replicate stock rocker guard ends so you can move the caps (here is what a stock end looks like):
Fold over pinch seam with BFH (big friendly hammer), sand underneath cut or flat flares, paint flat black, also sand rear most pinch seam and paint it flat black so the 1" body lift is less obvious. Sand inner rear fender well and paint with Duplicolor bedliner (looks better than trimmed stock inner liner):
Sand and paint flat black under the front trimmed flares, and drill a couple small holes through the bottom part of the front inner fender liner so you can zip tie it to the body mount to hold it in place:
You will need 2.5" extended rear bumpstops. Here are mine from my original 2.5" TF BB when I had my Xenons installed:
You can run stock front bumpstops without rubbing, but your springs will fully compress. I later added 1" extended front bumpstops from JKS (the kind that you bolt to the bottom of the front spring perch). Here is a full stuff on stock front bumpstops and 37s (pre-OME LT shocks and extended brakelines):
Discussion Starter · #2 ·
Barely touched with compressed front bumpstops and Xenon flares:
Wife driving with front compressed on stock bumpstops:
Wife also driving with stuffed rear tire (those tires and wheels are now on her rig):
Install front axle sleeves, C gussets, box in lower control arm brackets with skids, and reinforce trackbar bracket on front axle:
Install chromoly front and rear axle shafts (didn't take any pics).
Install minimum 5.13 gears, and preferably 5.38 gears if you have an automatic (no install pics).
Install Superchips Flashpaq.
Adjust front steering stops with 4-6 washers to avoid rubbing tires on frame rail with full lock turn. Not my pics, but here is is a write-up:
Project-JK.com - Jeep JK Wrangler Resource Jeep JK Wrangler Steer Stop Adjustment
Discussion Starter · #3 ·
Here are the results with the upgrade from the 2.5" Teraflex BB, with 4dr Rubi take-off front springs, and Skyjacker Hydro shocks for a 2.5" to 3" lift...
to the current OME HD 3" springs with OME long travel shocks, extended brakelines, Currie front lower adjustable arms, JKS adjustable front trackbar, Rubicon Express rear adjustable trackbar, JKS rear upper adjustable control arms, JKS 1.25" front extended bumpstop, and keeping the 2.5" rear Teraflex extended bumpstop:
And from the 2010 EJS:
And now, I am on 40s. Here is the thread:
http://www.jkowners.com/forum/showthread.php?t=28802
Dang, that sure is a lot of bump stop in the rear.
Not sure I could do a body lift on a Wrangler, how are they doing it with the manuals. Just a shifter extension?
Discussion Starter · #7 ·
RC has a 1.25" BL with a shifter extension for manuals. You can buy the extension separately if you want to stick with a 1" BL.
I did my 1" BL without an extension and had to trim the inner shifter boot.
If you run rear upper and lower control arms, you can move your rear axle back in the wheel well. Then, you can run shorter rear extended bumpstops. However, even at a 0.75" stretch, you need to modify your frame side trackbar mount and relocate your rear swaybar back on the frame.
Thanks for the info Plan, you are a wealth of info!
Do you have any pics or a write-up on this?
Discussion Starter · #11 ·
This is from Jon (Co4Lo):
I essentially did the same thing but cut off the unused side of the stock bracket.
With regard to the rear swaybar relocation, in the stock location it is secured by two bolts. I moved the mounting location back one bolt hole, drilled and tapped a new hole in the frame, used a piece of steel with 2 holes drilled in it as a spacer, and reinstalled it with longer bolts.
I have more sway now, so I am going to install a Full Traction HD rear swaybar. Without it, my ESP kept going off after installing my hardtop for winter.
What kind of shocks are you running (OME Long Travel)?
More important question is what the least amount of bump stop you need to run to keep the OME LT shocks from bottoming out. I plan to run 35’s on 2” suspension lift and flat flares but I wanted to use the OME long travel shocks. I am a little bit worried about not having enough up travel with the OME LT shocks.
I started a thread with some specs of the OME and Bilstein shocks.
http://www.jkowners.com/forum/showthread.php?p=731935&posted=1#post731935
Discussion Starter · #14 ·
Yes. I'm running the OME LT shocks. I needed 1.25" in the front and 2.5" in the rear for extended bumpstops.
However, you will need both front and rear extended brakelines.
Also, 2" rear springs will fall out at full shock droop without lower coil retainers combined with either upper coil retainers, or limiting straps, or something like the Teraflex 0.5" rear upper coil spacer that has a long center coil guide.
With the OME LT and 2" lift, both front and rear coils will unseat on full droop. The front doesn't matter as much if you run a lower coil perch bumpstop extension.
You also would need to extend your axle breather tubes front and rear, and in the front, you need to either reroute over the top of the knuckle or splice in an extension to your ABS lines.
Sent from my DROIDX using Tapatalk
Thanks for the info!!!!
I have a couple more questions.
What OME springs do you have? I plan on getting 616 fronts and 618 rears. My 2 door will be heavy with full armor, bumpers, full size spare, and skids. I probably will get more like 2.5” lift out of the HD 2 door springs.
How much up travel do you have at 3” lift and the OME LT shocks? I think 4.5” of up travel is a good number to shoot for. Anything below 4.5, I am worried that I will be riding on the bump stop during daily driving.
Are you running stock drive shafts? Auto or Stick?
I didn't read the entire thread. This may have been addressed, but in the following pic, what is keeping your passenger front tire from touching the ground? Limit strap? Fully extended shock? Also, I can't tell if you have a 44 or 60 under there.
Discussion Starter · #17 ·
In that picture, it might be the swaybar link before the shock was fully extended, but it is pretty close. On the next obstacle, I ended up pretzeling the passenger side link over the drag link because the shock fully extended and the link inverted forward.
Now I run longer front links, and my shocks are the limiting factor.
They are 44s.
The front is sleeved and gusseted, with chromoly shafts and Dynatrac ball joints.
The rear has chromoly shafts, JKS weld-on axle side trackbar bracket, and EVO RockStar skids.
Reviving an older thread here, but what bumpstop do you recommend for a 4DR with flat flares and no BL? Rear seams and rails are trimmed, but I get very little up travel before contacting the rear bumper. And I can easily get into the pinch seam, too, even with them trimmed.
Oh...and that pretzeling the swaybar link over the drag link issue you mentioned? Did that this weekend over a burm on our MX track behind the subdivision. Longer pins en route.
Discussion Starter · #20 ·
For the front, either JKS or RK adjustables, or TF front uppers.
For the rear, you could do the RK weld on adjustables, TF rears with 1/4" steel plates cut and drilled to match the stock lower pad, or you could do something that approximates 3.5".
I don't like extending the bumpstops taller than the amount of lift. That is why I like 2.5" rear extended bumpstops with a 2.5" lift and 1" body lift over 3"-3.5" extended bumpstops with a 2.5" lift.
Or, you could remove your rear bumper and buy something with more clearance, and then you could cut your rear fender well pinch seam more.
1 - 20 of 46 Posts
