1 - 10 of 10 Posts
how much air should i run in a nitto terra grappler 33 inch tire? like 35 psi ,doesnt say on the side??
33" Tera grappler.....
I would run about 30-35 yeah.
Do a chalk test. Get some sidewalk chalk and draw a big thick line across your tire....then drive a little bit and look at the chalk on the tire. You want it to all wear off evenly...
i run 36psi in my procomp extreme at's
You may want to do a chalk test as well...36 seems a bit high.
Look at your tires and see if they are wearing a little more in the middle than the edges...
:shaking: I run 28 psi in my Hankooks (33.6")around town, then bump to 35 for any appreciable freeway travel
:grinpimp::grinpimp: JIMBO
I did a chalk test on my GY MTR's w/Kevlar and I run 28 lbs on the street and air down to 18 on the trail.
i was actually just looking at the chalk line on them earlier and id say i have about a 1/2" to an inch before the chalk line comes should i let out some air to what?
1 - 10 of 10 Posts
