Make sure you select the correct download.
In the USA/Canada/Mexico For North America (Canada and USA) US English, Canadian French and Mexican Spanish RER MyGIG Radios
Outside of the USA/Canada/Mexico :These versions are for MyGIG REZ radios distributed in Australia, Middle East, And South Africa.. NOT for United States
Europe : For European MyGIG Radios ( 9 languages supported )
Install and burn procedure:
Instructions:
NOTES AND WARNINGS:
New UConnect Functionality – support of Phone Book Download from compatible Bluetooth Hands Free Phones. A paired phone will automatically download phone numbers to the MyGIG address book. Radio provides Voice Recognition to all names in this download. User can manually store individual names to the permanent address book.
Added more Bluetooth Compatible phones (many new phones including Motorola Q)
Human Machine Interface (HMI) improvements
Added Alpha jump to HDD lists (select first letter in a list instead of scrolling through list)
Moved JB (Juke Box) tab to FAVORITES under HDD
New progress icon for downloading music
Changed some POI icons on the map (removed yellow background)
Added phone book download status icon under UConnect screen.
Improved reliability of downloading Maps, Gracenote and application updates
Major Bug fixes
Fixed all audio mutes (missing audio) on Start Up.
Increased the number of Sirius Traffic messages and speed/flow
If you have a problem after MyGig Update:
A simple fix for 99% of the problems is this:
Open the hood and disconnect the NEGATIVE - battery lead for 10 mins, then reconnect and wait, everything should load back and be as good as new..if it isnt straight away, give it time, it will come online.
With NAV Mygig (US/CA/MX-RER) http://mofv.com/MyGIG/WithNav/RER_9.807.zip
With out Nav Mygig (US/CA/MX-REN) http://mofv.com/MyGIG/NoNav/REN_9.112.zip
With Nav (NON US-AU/ZA/ME-REP) http://mofv.com/MyGIG/WithNav/REP/REP_9.303.zip
With Out Nav (NON US-AU/ZA/ME-REZ) http://mofv.com/MyGIG/NoNav/REN_9.112.zip
With Nav (NON US-EU-REW): http://mofv.com/MyGIG/WithNav/RER_9.713.zip
Instructions:
Unzip the files to your Hard drive and burn them to a CD data disc:
1. For Version 9.807 - Name the CD to RER_9.807 when burning it. (Recommended)
1. For Version 9.112 - Name the CD to RER_9.112 when burning it. (Recommended)
Burn the CD at 2x speed for maximum reliability, and disable multisession (Add files later) on your burning software. (nero)
2. Root directory MUST contain only one folder and two files:
BECKER (folder)
CD_INFO.CDI
CONFIG.CDI
Start your car (Recommended), Load the CD in your MyGIG radio and the update will automatically start once the disc is recognized. Updating will take around 15 minutes.
For Version 9.807 - Click the No soft key prompt window then Remove the CD after you see the "Update from 9.807 to 9.807" screen.
For Version 9.112 - Click the No soft key prompt window then Remove the CD after you see the "Update from 9.112 to 9.112" screen.
. 1. For Version 9.807 - Name the CD to RER_9.807 when burning it. (Recommended)
BECKER (folder)
CD_INFO.CDI
CONFIG.CDI
NOTES AND WARNINGS:
Do not turn off your radio, turn off your car, Turn off your Ignition, or start your car while the update is in progress.
For Version 9.807 - Do NOT remove the CD until after you click No on the "Update from 9.807 to 9.807" screen.
For Version 9.715 - Do NOT remove the CD until after you click No on the "Update from 9.715 to 9.715" screen.
Major Bug fixes
