I meant to ask some about this before, but forgot, you have the PSC BFH? When you did the install and had to cut the crash bar and frame rail, what did you use? I know there are a bunch of options to cut metal but, wanted to see if would make a difference in what I used, Im think a reciprocating saw would be the cheapest route considering my tool selection is very limited.Just keep them rotated often, they'll be fine.
We had a plasma at our disposal and did not use it for the frame. The problem with the plasma is its so precise and you would have to do four different cuts...which aren't going to be very straight. At least compared to the results we got with the sawzall.I used a sawzall for mine it worked out well if you know someone with a plasma cutters that would make quick work of it, good luck![]()
Ya that does make sense thanks for the clarificationWe had a plasma at our disposal and did not use it for the frame. The problem with the plasma is its so precise and you would have to do four different cuts...which aren't going to be very straight. At least compared to the results we got with the sawzall.
We did use the plasma for the crash bar however.
Sent via paper airplane
Rotate every 3k.... I didn't and waited for te first 10k and now they have work weird.....Just keep them rotated often, they'll be fine.
Your upper c"s are the weak spot..take a look there hour glassed...just take care those n u should be fine..I run a much heavier tire and havnt had any issuesWell I guess my next move is to reinforce my front axle. You guys think tthat upper/lower c gussets will suffice on a d30 with 35s? Adding an inner sleeve costs a lot and I dont wanna have to pay for the labor of adding it if simply adding the gussets will offer enough protection. What do you think?
I have 61k on my jeep and 50k with 35's on it and a stock d30 with no upgrades or bends.Well I guess my next move is to reinforce my front axle. You guys think tthat upper/lower c gussets will suffice on a d30 with 35s? Adding an inner sleeve costs a lot and I dont wanna have to pay for the labor of adding it if simply adding the gussets will offer enough protection. What do you think?
