Tried to use the horn today and it won't work. Horn sounds when I hit the key fob lock button so the horn itself is ok, but when I hit the steering wheel ... she no work.
I swapped out the fuses and checked the physical connections. They look good. I don't want to spend half a day at the dealer if I don't have to. Don't want to rip the steering wheel apart unless it's an easy fix. (airbag and all).
Thoughts?
Thanks,
Duffy
No ESP, no other idiot lights either. I have no idea how long it hasn't worked. Don't use the horn very often. I can yell louder. I just happened to hit it as I was passing a buddy.
If it is the clock spring I'm under warranty, just the hour drive and however long it takes at the dealer I was trying to avoid. They have been good to me, but stuff takes time. Time is in short supply these days.
Oh well... suck it up buttercup.
Thanks guys.
Duffy
