1 - 14 of 14 Posts
I was driving downt o beach on the highway, going about 70 and my hood was bouncing like it was about to suddenly just fling open, and the latches were gonna give way. Did the same thing coming back yesturday.....any thoughts as to if something might be wrong cause i cant find anything.....
search hood flutter
dozens of threads on it.
some people take out the lift spring at the front
others swap factory rubber latches for daystar replacements
some add 1/2" square steel to the latch hook
others just learn to ignore it
mines been doing it for 4+ years
search hood flutter
dont forget zipties
dont forget zipties
x2... you'll need the 11" ones. i just replaced mine. had one break after 4 years, so replaced both. cheap and easy. :)
I used the Daystar Hood Wranglers. They work great!
Remove the lift spring.
The hood latches are working as designed and are suposta flex. They were designed by a battery of Jeep engineers, there is no need to 'improve' them. Waste of money.
:shitstorm:
Daystar latch replacements! I just replaced mine last week and Daystar is the way to go. For a total of 30 dollars including shipping you cant ask for more. The only thing that I did other than the latches was make jeep aware I was unhappy... I can tell you I gained 2MPG because the air is not trying to rip my hood off.
1 - 14 of 14 Posts
