1 - 9 of 9 Posts
Just installed a set of Lightforce Strykers and need to find the highbeam power wire from the back of the headlight. Anyone have a wiring diagram handy that can tell me what color that wire is?
Thanks
White/Slate wire
Thank You! Much appreciated..
I found that connecting the wire to the low beam wire works best when the hi beams come on that will cut the power to the Strikers.
You want the Strykers to shut down when you shut down your hi beams. As in the other thread on this subject, you must use a relay or take the chance of major electrical issues.
2 door 2010 JK sport
I know this is an old thread... however I'm looking for the high beam wire on my 2012 JK. I have 3 wires on the drivers side plug. Black, White/green and white/blue.
Any clue which one (the white/green and the white/blue) is for the high beams?
How about the low beam wire? Trying to install PIAAs using low beam wire, not sure which one it is
C'mon man. There are only three wires and the black is the common ground wire. I think you can figure it out with the information already given in the post above yours.
1 - 9 of 9 Posts
