1 - 20 of 112 Posts
Ok looking for some opinions. I've been doing some searching and reading on the different headlight options. My first option is the HID conversion from VVME. I know i'll probably go with the 4300 or 6000k kit, cancellors and whatever else i need. Would this be all i need to make it work? I read about flickering and bulbs turning off then people putting in resistors and capacitors and yada yada yada. Can someone tell me what i would actually need to make it work right and if it would be my best option compared to the cibie's and ipf's
Option two are the cibies from david stern. I'll probably talk to him and see what i need but was thinking on doing his wiring harness and the brightest bulbs i can get.
Last option is the IPF's from northridge and some Philips 80+ bulbs.
I'll be doing my fog lights also in the process.
Whats everyones thoughts on this and what would give me the best and most hassle free setup?
Hid should be keep off the road even properly aimed they are hard for other people and hard for your eyes, you end up having hard time focusing on the road.
Daniel Stern is a better choice and susqueanna make a great kit to, take the time to align them properly and you’ll get great lightning for a decent price.
http://www.rallylights.com/detail.aspx?ID=4669
IPF seem to have good and bad review, my only concern about them would be the fact they use the stock wiring which is not the greatest but you can always upgrade that yourself.
As for the fog I like the delta replacement kit, or if you don’t mind the stock one the TJ use to have mount on the bumper where fantastic in my opinion. I’m sure you can find a used set for a decent price.
Just to say most HID sucks in snow rain and fog ………..
Im probably going to get shit for this but i have HID's in Cibies and HID fogs and rarely had people flash me or friends tell me it was bothersome (until i added the rear bumper and leveled myself out :( . . . now i need to re-aim). I think they're perfect for the majority of city/highway driving i do. thought my PIAA 580's dont have the same long range effect they used to because of it. . . . thus im looking to upgrade to lightforce :bounce:
I’m working as security and sometime I have to drive for 12 hours, 14 if you had the drive back and forth from town, we had some F150 with stock HID(put by the renting company i guess) and they had to replace them with halogen because they where to hard for the eyes after a while .I can seriously tell while the HID is brighter after a certain time it really get to you.
I forgot CiBies existed and got a set of Silverstar platinums. They worked really well but I was left wanting more. I got a full on workup harness, housings and bulbs from Mr Stern. I am amazed at my CiBie's when just an hour before I had the wagners and those were and improvement. I go toe to toe with my buddies Jeep with H.I.D's and On High Beam I throw more light further. Lows I am at the same brightness levels without the "Glare" that his 8K Hid's gives off right back at your eyes.
H.I.D's consume less wattage :smokin: H.I.D Ballasts do not like vibration and water :shaking: H.I.D "kits" are no bueno in factory housings as the housings reflector was not designed that way from the factory. DEFINITELY not DOT compliant.
CiBies use E-Code lamps (E=Europe) and again are not DOT compliant. The lenses are made to focus ligt where it is needed .. not just broadcast ass loads of light. The pattern has a dual__/ __/ cutoff to them that is nice but is more suited for driving on "The wrong side" of the road.
CiBies do cost more when done right (Harness upgrade , Housings and Bulbs in the 3 and a half range) Whereas HID kits are in the 2 and change mark average.
As for the biggest baddest bulbs he has ... Trust me when I say no need .... Unless you want to plasma cut Cacti from 100 Feet. I run the 70/65W Osram Plus 50 bulbs and again they are stupid bright. Plus with the JK's frail electrical system in terms of voltage sensitivity and drop ... Meh why add to the woes.
Don’t want to be a party breaker but 99% European country do drive on the same side as we do….so proper E-code will be align the proper way as long you not buying them from UK. E-code are legal in Canada luckily we even receive time to time car equipped with them, back in the days my old Volkswagen jetta was coming with them and I loved it. The down side is they are harder to aim properly.
http://en.wikipedia.org/wiki/File:Countries_driving_on_the_left_or_right.svg
2 door 2010 JK sport
Cibies. I already have an HID kit to put in this JK (waiting for it to warm up outside - damn -40). But the next JK I'll go with cibies and good fogs.
The HID kit you mentioned is illegal and dangerous; forget about it.
Valeo/Sylvania makes a bixenon projector that you can jigger in that would work but it's not a simple drop-in.
JWSpeaker #8700 is an LED array that is supposedly pretty sweet. They cost big money though.
Rallylights has a kit that's properly set up but the Hella reflectors they provide have too much foreground lighting and too little light to the side; the photometry analysis on them shows this.
Dan Stern sells a similar kit and provides Cibie reflectors; they're pretty much the best H4 reflectors you can get for the price. He also has some more exotic reflectors if you have the money; I'm installing a set of Z-Beams today. :bounce:
The IPF kit you mention has lots of flaws. As was previously mentioned, their pigtail harness just exacerbates the stock voltage drop condition and creates additional resistance. The reflectors are also illegal for on-road use in the United States, Canada, Mexico, and Europe. IPF went as far as to put a bogus "E" in a circle to make it look like a proper ECE stamp ----- don't be fooled, it isn't. Their own literature on the reflectors says something to the effect "suitable for race and rally use".
I have the EXACT same setup. Lenses, harness and Osrams from Daniel Stern. I needed more light because I drive on FT Bragg most mornings, and there's a metric shit ton of soldiers crossing Gruber rd to get to formation/PT. The color of the light helps out as much as the amount of light.
Discussion Starter #10 (Edited)
Thanks guys i appreciate all the info. I was considering the HID's but if they are not good with water and stuff, then they are out.
I think i'll look into the Cibies from Daniel Stern. I'll have to wait and talk to him to see what he thinks. I just need something upgraded from what i have now. THese JK lights are horrible.
I was really wondering also on the IPF upgrade. I heard alot of good things and now i read a couple bad things about them. And i really haven't heard much about people buying them anymore. Plus they have dropped 20 bucks in price. Something must have been up. I guess they really weren't worth the money and headaches.
Cibies from Daniel Stern it is then.
I have the IPF headlights and I think they are a great upgrade from stock. I don't think the bulbs are high enough wattage to fry the stock electrical system, but the lenses just spread the light into a much more effective beam pattern.
I don't know anything about them being legal/illegal though. I'll have to read up on that.
I run hella E codes with 6k 55watt HID's with a harness/relay kit. I have no complaints what so ever. I rarely get flashed also. HID's in a good housing is what makes the best/safest improvement.
Sent from my Motorola bag phone
Discussion Starter #13
I'd like to have HID's but i'm kinda worried about them with vibrations, offroad abuse, water and the harsh winter. I'm probably gonna just go with Cibie's and some Philips Xtreme 80+ bulbs. I haven't figured out what to do with the fogs yet.
Discussion Starter #14
What color is the best. I was going for a more white. I don't want blue at all.
How can you call an illegal kit like that a "best/safest improvement"?
The reason they're illegal is that they're not safe --- especially for oncoming motorists.
Read these facts about bootleg HID retrofits from DS's website.
I have the Cibie from daniel stern in stock wattage and am using the stock wiring harness. I made my own pigtails to go from h13 to h4. I had planned to eventually upgrade to a full harness which is why I went with the stock wattage bulbs for now.
once I installed these lights it was so fantastic that I see no reason to upgrade. experts often say you don't need a lot of wattage you just need it pointed in the right direction. I guess upgrading the harness might improve it some, but the lighting is so great now and the beam so precise, I don't see any reason to spend more money.
Sent from my EVO using Tapatalk
The same reasoning followed when I decided on the IPF lights.
if you talk to daniel stern he will talk you out of the ipf and into the cibie. I honestly can't say about the Ipf personally I can just tell you my lights are fantastic.
I Know just throwing a "Razz" on the common belief.
The main reason for the additional harness is to take the higher capacity battery voltage and bring it to the lights via heavy duty relay circuitry. This takes the load off the Jeep';s Switch and harness.
1 - 20 of 112 Posts
