1 - 13 of 13 Posts
So who here has them and what is your exact set up? I like my Delta Quad Bar lights but am not totally satisfied with the quality of them. I tried the search button but didn't find specific information on anybody's HID set ups. Thanks for your help. :beer:
irate4x4 dot com
Hella H4 buckets with a quality Bi-xenon HID kit..... can't remember the make
euro efx bixenon (high and low) and fogs as well, good set up, I wish the pigtails were longer for the feed to the bulbs to be able to get the boxes higher and out of the way even though they use weatherpack connectors. stock housings light is great, the fog lights alone put off more light than the high beams. I have the cebie set up laying on my study floor, I got tired of farting with the make your own relay kit stern sent and ordered this, figured when the bulbs go out ill get the hid bulbs for the cebies and the lights will probably be way better.
Thanks for the quick reply :beer:
irate4x4 dot com
Did they directly bolt in, or did you have to make any modifications?
no mods to make the lamp housings fit
just about any 7" lamp housing will work in the JK. The notable exception being those bi-xenon lamps you can get for motorcycles XeR7s or something like that. The bodies on those are too deep (beause the starter/ballast are integrated into the rear of the lamp and make the whole thing deeper) and you will have to move the impact sensor for the airbags to make them fit depth-wise.
Have you had any issues with moisture building up inside the hella lamp housings?
irate4x4 dot com
no. I was concerned because they are vented but since they supposedly work so well with patterning HID, I went ahead and got them. Been a year and I've never even noticed moisture and extremely happy.
I'm sure condensation can occur but I've not noticed any.
Discussion Starter #11
Did you ever try the HID bulbs in the stock housings?
irate4x4 dot com
No, the stockers weren't designed for HID and will scatter the light too much. Not only are they inefficient for HID they will bother oncoming drivers
1 - 13 of 13 Posts
