at some point, someone appears to have broken the lever on the winch...it does nothing
before I tear into it, is there anything I should be aware of w/the internals (I know nothing about their guts)
Well first remove the lever and see what is broken on it and if you can retrieve the broken off parts. Lever should be held in place by a socket head screw from the side. Remove the screw, pull the lever out and inspect it.
IIRC You have to take the end plate off on a T-Max winch to get the clutch lever off, 12 or so hex bolts. Not difficult to strip down a T-Max winch, if you haven't done it before, take a photo at each stage, it will make it much easier to put back together.
BTW which T-Max winch are we talking about here?
Off-Road, Outback or Performance Series?
