1 - 10 of 10 Posts
You know how google is useless unless you know the words for the bits you're searching for. Trust me, I've sent hours searching and I can't find an answer to this simple question... Please help.
I've added power locks to my JKU. Now I want to take the doors off and I realize I should have added the new wires to the existing door harness disconnect, so it's time for a quick rewire. Except I can't work out how to add wires to the disconnect.
The mopar connector has holes for about 10 wires. Stock is using 2 of them. So I should just be able to buy pins, cut my cables, crimp them, and push them in to the connector. But no pin I buy fits. Where do I get pins that fit the connectors?
thanks
Gunnery Sergeant USMC (ret)
Mouser doesn't sell the connectors in small qualities, Waytek does.
Qty Item Description UOM Price Total
50 30471 Delphi 12191818 GT 150 Series, 22-20 GA Female Loose Terminal EA 0.0765 $3.82
50 30470 Delphi 15326268 GT 150 Series, 22-20 GA, Sealed Loose Male Terminal EA 0.0690 $3.45
Just cut the dam connector off and use a weatherpack. No sense in beating the head against the wall over and over again and again.
1 - 10 of 10 Posts
