1 - 2 of 2 Posts
What is that Rear Track Bar eliminator thingy, I saw it a few months ago on here.
It has a bracket that mounts to the passenger side of the frame, with a link that mounts to a truss, that is directly over your rear diff.
I think it uses a Johnnie Joint instead of a bushing.
I can't for the life of me remember who makes it.:bawling:
Thanks
umm what you're describing wouldnt work - you make it sound like essentially a half length tack bar?
frame rail to center of axle (diff) would work similar to a track bar but would double the side to side movement through the arc of articulation because the bar would be half length..
I think you may be referring to a Rock Krawler triple threat 3 link that replaces the 2 upper arms with a single, centered link running from a truss over the diff up to a mount of the cross member in the center of the jeep.
longways centered link, not side to side
http://www.rockkrawler.com/pages/catalog/index.php?r_itemID=223
1 - 2 of 2 Posts
