1 - 9 of 9 Posts
hey guys I have a 9000k winch is a badland I bought from harbor freight for some reason I try to test it out today and it worked perfectly fine, 30 minutes later i was gonna show it to my neighbor and i pull the cable out and when i tried to pull it back in it did not work at all any ideas what could be?
i was planning to go wheeling this weekend but i cnt go now thanks to the stupid cable hanging out :(
R.I.P. Mr. Nibbles!
More details on install would be helpful. Did it come with a 150A circuit breaker array or any kind of protection to install between the battery and motor? Does it click? More info would help.
it came with 3 150A circuit breaker between the winch and the battery and no when i press the out button it does go out and starts working but when i press the in button nothing happens
R.I.P. Mr. Nibbles!
Your remote has a loose connection or a bad switch more than likely. See, those are little details that change the response you get. The remote should have three pins. If you have a digital multimeter, you can check the pins on the control to rule it out by finding the common pin and the checking both sides of the switch. Refer to my rudimentary drawing I just whipped up. One of the pins is the center of the toggle switch. One of the pins sends +12vdc to the IN solenoid and one of the pins sends +12vdc to the out solenoid. If only one side tones out, either exchange the controller or replace the toggle switch.
Fuck the winch. Pull the cable off or wrap it around the bumper. Toss your Hi-Lift in the back and go wheeling this weekend!
x2 you dont need a winch to go off roading, take that bad boy off and go have some fun. Deal with it when you get back, or take it back to the harbor freight ya got it from. And if your going by your self, just dont do any thing real crazy that might require you to have a winch. All ya really need is a tow strap and some one can get ya out of where your stuck. :beer: :beer:
thanks I will have to check that tomorrow!!!!
by the way i like your drawing thanks it really does help!!!!
Take it back!
it only has 90 days warranty which is BS
I wrapped the cable around it and decided to go camping had a good time anyway.
i got the same winch on my wifes jeep. never had that problem but are u sure the disconnect lever is fully engaged?
Sent from my DROIDX using Tapatalk 2
yeah it is fully engaged cus thats the way i installed it and there is no way to move the lever since there is no room at all. but thanks!!!!
yeah thats true and if I go its for sure I'm not going by myself
THANKS EVERYONE FOR THE HELP I REALLY APPRECIATED!!!!! :bounce:
1 - 9 of 9 Posts
