1 - 20 of 29 Posts
I was on a road trip from Scranton, PA to Bronx, NY to see some family over the weekend. And on the way back from NY I was changing lanes and all of a sudden my front right brake locks up and pulls to the right hard almost hit 2 cars. After that the ESP/BAS light Traction Low light on and ABS lights all stayed on. And now they wont go off. Now I read a tech release about how jeeps that have bigger tires and lifts will experience early ESP activation.
I have also read a lot of posts on this issue and all of them have said that jeep doesnt know what causes all these issues at the same time except for a bad sensor. However those people who do take their jeeps to the stealership have experienced extremely long wait times for repair. Anyone know what could be causing this or does it NEED to be brought to the dealership.
...slightly sane.
i had a steering angle sensor go bad that caused right turns to freak out the ESP/BAS. however, it took it's sweet time going bad enough to pop an error code.
during the few months of sporadic problems with it, neither the dealer or myself could find anything off. we'd re-center a centered steering wheel and it would fix it temporarily. however, once the computer finally popped the DTC code, the dealership had it fixed a few hours after i dropped it off.
that was months ago, still running the same 35s and haven't had a single ESP/BAS problem (... that i didn't cause with pedal usage)
after your lift, did the steering wheel get centered?
all the lift and steering components were torqued down (and rechecked a couple hundred miles later) while the jeep was resting on it's own weight?
Discussion Starter · #3 ·
I bought the jeep used and the lift was installed before I got it. Its only a 2" BB. The vehicle just had an alignment about a month ago. Does the dealer have to center the steering wheel.
...slightly sane.
agree with venom below, steering off center should not cause a swerve event from the ESP/BAS kicking in. here is how to center anyway though.
assuming that you still have the factory drag link for steering:
no need for the dealer, is easier with someone to help by watching for the wheel to be centered.
1) is your wheel off-center? jeep logo is not flat when going straight?
2) if not centered, loosen the two bolts circled
3) twist the metal in between the bolts either up or down, note which way the steering wheel turned in the jeep (why it's easier to have a watcher)
4) adjust the steering wheel so the logo is flat
5) re-torque the drag link bolts.
really easy, and on the factory drag link you may have to do it every 2-3 wheeling trips depending on how rough you wheel.
its probably your left front wheel speed sensor
good chance your left front unit bearing is shot too
the bearing goes, then coats the sensor in melted grease/metal powder and it cant see the sensor anymore
or the heat from the bad bearing will actually melt the sensor
the computer responds by nailing the right front brake
same thing happened to mine
you can recenter the steering wheel yourself in about 5 minutes but that doesnt sound like what you have going on
jack up the front wheels one side at a time, push in and out on the top pretty hard and see if there's slop
if there is, get ready to shell out $100 for a new unit bearing.
luckily it comes with the sensor installed
if theres no play, then you can pull and clean the sensors pretty easily - 1 5mm allen bolt holds it in.
YouTube - ‪IMG_0621.MOV‬‏
Discussion Starter · #6 ·
Ill take a look at it. Its pretty damn hot out today 94 with 100% humidity. How hard is that bearing to replace? Do I need to pull apart the whole left side of my axle? Im pretty new to jeeps. I had a WRX before this and the only traction control was me. So all these BS safety features sort of annoy me.
nah, unit bearing is easy to replace
takes about 30 min maybe - pull the wheel, the brake caliper & bracket, the big axle nut, the rotor and then 3 bolts hold the bearing on
something pretty close to that going from memory - its easy
worst part is the plug for the wheel speed sensor line is behind the shock tower and a bitch to get apart
your wrx had abs too ;)
Discussion Starter · #8 ·
Would it be the axle bearing that would need to be replaced basically. Like I said, I will check tomorrow and see if thats bad. If it is. Ill order the part and saturday take a road trip to my in-laws and do the bearing. If its not that my friend down stairs said it could be a faulty Dynamic vehicle sensor and a clock spring possible.
clock spring shouldnt cause the brakes to respond
I had the exact same problem, my jeep kept hitting the right front brake on me and it ended up being the LF wheel bearing/sensor
that be it
good luck finding the timken part tho
it was on national backorder when I tried to get it for mine, had to pay the extra $ and get mopar, which is the same thing
You've probably already done this but go around each wheel and check you sensor wires. When my Christmas tree was lighting up on the dash it was do to one of the front sensor wires getting pulled out of the bracket to do flexing and then it rubbed on the knuckles of the front shaft. I cut and spliced the wires and reconnected everything and the abs/ebs traction control light turned off after driving about 50 feet.
Discussion Starter · #16 ·
I will definitely look around. But this seems to be something a little different I actually dont flex the jeep, and this only happened once. But like I said the front right wheel locked up and pulled me pretty hard and when the lights arent one like the computer resets them when it does start to happen the ABS system activated seemingly random times and almost sounds like my brakes are grinding but its the ABS, but I will check all the ABS wires and see if I can find anything out of place.
Sounds like a bit of a different issue than what I had, though it's easy to give it a look over just to make sure. Hope you get it taken care of!
Discussion Starter · #18 ·
Was doing my own diagnostics today and noticed that every morning the ESP/BAS, TRAC LOW, and ABS lights go off. Then when I get above 45mph it seems to start with the ABS right front going crazy then the other lights come on. So I dont know if its the Vehicle Dynamic sensor or that unit bearing going. Looks like its gotta go to jeep :(
Discussion Starter · #19 ·
And now a new added issue. Ive noticed the MPG of my jeep has dropped dramatically since all these issues started. I did some MPG calculations real world numbers. I drove 75 miles on 6.3 gallons. Which is 11.9 MPG Which would mean somethings really really wrong with my jeep. My jeep is hardly modified, 2"BB and 32" tires. So I shouldnt be getting that low of MPG.
Discussion Starter · #20 ·
Ok new update in this issue.
I contact Jeep and they say they need to scan my ECU and see if a sensor is off or faulted. But they said after I went to them that there were no open faults. Now 2 weeks later, no problems, all of a sudden this morning, the issue happens again. 1 month exactly from when the issue first happened. Jeep still doesnt know whats wrong and still can NOT recreate the issue. Ive checked my left from unit bearing and there is no play in the bearing. Anyone know what else it can be!!!!!
1 - 20 of 29 Posts
