Vendor
Getting this out there early incase anyone interested. Selling my axles from my 2011 jeep jk. The jeep has only 31k miles. Jeep is not my daily driver so wont be adding much more milage on the axles. New axles are on order and going to be going 40s. Space is tight so i wont be able to remove them until new axles arrive in about 6 weeks. These axles are setup to handle 37s all day long on the trail. Located in Tucson Az and asking 5700 or best offer. I can ship them if buyer pays shipping. I can probably use my crate that the new ones come on.
Front Dana 44 Rubicon Axle:
Factory Rubicon Housing
Factory Spicer E-Locker
4:10 Gears
ARB diff cover
Lubelocker diff cover seal
Axle is sleeved
Artec Truss
Artec C-Gussets
Artec Heavy Duty Raised Track Bar Bracket
Currie Front Upper Johnny Joints
Dynatrac Prosteer Ball Joints
Reid Racing Knuckles
RCV Axle Shafts
Setup for Ram assist
Dynatrac Pro Grip brake kit with 13.5 inch rotors
Artec lower control arm skids
Synergy lower shock relocation to keep from hitting frame
Rear Dana 44 Rubicon Axle
4:10 Gears
ARB Diff cover
Rock Krawler 3 link truss
Upper control arm mounts are partially cut off could fully cut them off and weld on upper mounts for 4 link
Rock Krawler heavy duty track bar mount
Raised Lower Shock Mounts 2 inches
Superior Chromoly Axle Shafts
Dynatrac Pro Grip rear brake kit with 14.25 inch rotors.
Axles will require at least 17inch rims to clear the dynatrac rotors. All mods have 10k miles except for brake kit which has 2500k miles. Never had any issues with these axles.
Sent from my SM-N960U using Tapatalk
