I like the idea, but i have a question... What's going to keep the tape from melting off?
You could probably substitute with a high-temp glue or epoxy, if you weren't worried about taking it off later.I like the idea, but i have a question... What's going to keep the tape from melting off?
WOW 90*+ I would feel for you but I just cant reach.... 110* today. :devil:I have been wheeling and driving with this for about 3 months in 90 + heat and it is firmly up their! The 3m Heavy duty tape said 3" will hold 4 lbs. and I think from the perimeter and strip in the center and middle it should hold like 50lbs so 9oz should be no problem. This is the same stuff the chevy dealers use to put the trim on the body of their cars and trucks!
I got it at Home depo.
I was running Rock Garden in Holcomb Valley, Big Bear. I know it is closed, but a forest ranger gave a group of us an escort thru there. Still a great trail, but so much burned.....Where were you in the second pic?
Btw, I am pretty sure I have seen you on the highway a couple times.
Holy crap, you specified carpet, not gold, right? You're right, that does seem high. I'd go and get a few more estimates.alright, I just got back and was quoted for a heat shield and carpeting over it for the tops and side panel in the back at $450. Seems a bit high but if it works, I'll probably do it. (It's 104 here todayissed
wow, that's a lot of scratch.alright, I just got back and was quoted for a heat shield and carpeting over it for the tops and side panel in the back at $450. Seems a bit high but if it works, I'll probably do it. (It's 104 here todayissed
No kidding, I'm sure if someone came up with something that many people would by. Can you swing by tonight and help put on a electronic disconnect? The "Unnamed" person is coming by to work on a few things around 8.wow, that's a lot of scratch.
